Hi, I know there are plenty of posts on this if you look for them on here.
But I wondering how many other Zed owners (particularly Newbies) are out there that don't know anything about this, like I didn't till this week. So like me, don't know about it to go looking for the info!
Hopeful a Mod can put this in the appropriate Info section if it meets the criteria.
When you change from runflats to non runflats did you stick with the standard tyre pressures (sticker on the door opening) or did you change to something else?
When I got my 2005 E85 3.0I SE last summer the first thing I did (two days later) was change the runflats to non run flats. Something I have done on quite a few BMW/Mini cars over the year and as usual it made a big difference. A lot less tramlining and the ride improved but still wasn't brilliant, not knowing any better I stuck with the standard pressures. Just like I have done on every previous BMW or Mini I'd made the change on.
Fast forward 7 months and just last week I stumbled on some of the posts on here about tyre pressures on here while actually looking for something else and discovered for the first time the intriguing fact the M model runs at much lower pressures. I always knew the M models didn't use rft tyres from the factory, but had just assumed their tyre pressures were about the same as the non M models. Well how wrong was I! The M's are considerably lower, particularly at the back. Fronts are 30 instead of 33. Rears 32 instead of 38! Considering the M is actually a heavier car than my 3.0i, about 100kgs or so heavier (mainly at the front as the S54 is a lot heavier than the M54).
This didn't make much sense, still doesn't if I am honest! The M is basically the same car as the mainstream Zed's. I know apart from the engine there are other notable differences, including axles/diff and a slight difference in tyre sizes. But I think most folks would agree, the basic structure of all 6 cylinder Zeds is very similar. This left me to conclude as others have the higher pressures are solely down to the design of RFT in some way. So I changed my tyre pressures to M specs. BIG Difference!!! Much bigger than the change of tyres to non RFT. The car doesn't really tramline at all now and the ride is vastly improved.
Wish I known this 7 months ago when i got it! The chances are as well, us non M owners would get away with pressures slightly lower than F30/R32 due to the weight difference our cars have over the M but for now I think I will stick with M pressures.
Does also call into question should I have reduced/played around with the tyre pressures on all my previous BMW/Mini cars i removed RFT from.
Like I said I hope this helps some Newbies/Long Standing Members who may also have been unaware of this, like I was and maybe this or something like it could be used in one of the How To/Info Sections of the Forum.
