I think OEM plugs are NGK on the N52, at least that was the spec for mine (06).
Do your coilpacks too (Bosch), Autodoc have them cheap usually and check part no if poss which was 221 504 467 but is now 221 504 470. Be careful when you shop for coilpacks you might get ones where the connector has a lug off-centre instead of central which happened to me so best to check manufacturer part no instead of relying on website.
