2016 supercharger
pokeybritches said:
The twin screw is well out of its ideal operating range at 15 psi,
No its not, the ideal operating range is between 9 and 15psi. Thats where the widest range of flow on the higher efficiencies take place.
But if you go to those kinds of boost, you'd have to lower the compression imho. (and then turbo is a really good option)
I don't know if the manifold can take 15psi. Easy to check though with a leakdown tester on the TB.
As for torque potential of the m54: it runs ok with 465Nm, so there is room for the stock vortech kit to tune (the stock kit does 372Nm I believe?).
Also the driveline runs fine with it.
How much torque makes your vortech @9psi btw?
