2006 Z4M Roadster Vibration at idle
Holmes312
Milton, Ontario
Hi!
I have a 2006 E85 with 67,000 kms on it. I feel vibrations when holding the steering wheel at idle. When I rev it a little, its perfectly fine. I also feel this vibration when I touch the front wheels. All of this during idle. Driving the car at any RPM over 1k, its fine. Could my engine mounts be the issue? Thanks!
I have a 2006 E86 and got the rod bearing shells and engine mounts replaced last year on 78,000 miles.
I hadn't noticed what you described, but the old mounts were definitely well past their best!
The shells didn't look pretty either. :(
If you have a good BMW specialist hopefully they could tell if the engine mounts were looking tired.
I would say engine mounts and / or engine mount bolts.
I doubt very much the VANOS would cause that unless you've got some serious issues, unless you mean the VANOS causing the engine to run a bit rough in which case that's possible.
I purchased the car in August. I also realized it got new mounts from bimmerworld in 2019...perhaps I just feel more with these mounts...I may replace with OEM mounts in the future
I have aftermarket mounts and yes, they vibrate more, to the point I see that vibration on the headlight cutoff lines. Considering going back to OE
