SteBrown91
Hi all,
My 2003 z4 has an occasional leak which looks like is because the drain hole at the top of the windscreen isn’t draining correctly. Water appears to gather here, eventually fill up and drips onto the passenger seat. I shoved a key into the gap into the rubber and seems to not be blocked near the top, so I assume it’s gunged up further down. Where does this drain run to?
It’s not a lot of water it’s just the odd drip after quick/heavy rainfall so it’s not a major problem but would like to get it sorted. If it’s not what I think it is do you have any ideas what it could be?
