Sailed through with just an observation on a low tyre... Phew!
Also thought I'd get it booked in a little early (Cooper BMW in Cobham) as warranty obv due to expire as well and mention 2 things;
Squeak from handbrake when getting in & out of car, was told that this is merely due to the design of the brake system & is not covered under warranty, they could strip down etc but this would be chargeable! Tried arguing that as the car was presumeably not designed to squeak then it was a fault that needs repairing but the guy was having none of it, said that he could not reclaim the work from BMW therefore they would not do it FOC. :thumbsdown:
Secondly, I've noticed a minor loss of power, only intermittantly & minor enough that if you didnt know the car you probably would notice it. I likened it to when you switch the air con on in a low powered car (my 1.3 Ka as the example), the engine just isnt as keen to rev, not really very noticable unless you are used to the car. He asked if I would be able to show a technician on a test drive, which, as the fault is 1) minor & 2) intermittant (only notice it maybe once a week) I wasn't sure I would be able to, in which case if they took the car on an hours test drive & didn't find a fault would be chargeable time.
I pressed him & in the end he agreed to run a computer diagnostic under warranty just to keep me happy... Anyways, the upshot is they have found a hairline crack in the exhaust manifold which apparantly could cause the symptons I've described - and they will do the work under warranty!
Am glad I pushed them to look at it under warranty - I think the fact that he refused the sqeak made me more determined as when he initially mentioned the chargeable test drive I was going to leave it, but thought sod it I'm going to get my moneys worth
On a different topic.... Sat in the new Z4 in the showroom as well... think I'm now converted - can't say I was overly keen like many people seeing the photos etc but in the metal it does look great, and the interior is stunning! Now I just need a £10k payrise & I'm good to go
