$10 Million, Just for Motor Oil
Shipkiller
Veteran
I do not watch NASCAR, but this is very interesting....esp, when some yokal tells me his oil is better because 'NASCAR uses it' or some advertisment says so, like Mobil One.
The most advanced piece of technology in a Nascar vehicle these days isn't its engine, its suspension or anything made of carbon fiber. It's the motor oil.
Joe Gibbs Racing, a team that owns three top-level Sprint Cup cars, has spent about $1 million a year over the past decade to perfect its motor oil. As a result, its engines have squeezed out an extra 10 horsepower, a roughly 2% increase that can be a serious advantage in Nascar races, where the typical margin of victory is about one second.
With Nascar increasingly cracking down on the use of technology in the sport to cut costs, motor oil is one of the last places teams can innovate without restraint. Companies like Shell, Quaker State and Mobil also make special oils packed with synthetic lubricants, new polymers and experimental molecules for the teams they sponsor.
All this has spawned a culture of secrecy. Shell was so worried about protecting its motor-oil formula that it recently refused to allow used race oil to be sold as a souvenir to Nascar fans. The concern, a spokesman said, is that someone could "reverse engineer" the used oil to see what its properties are. Joe Gibbs Racing, one of Nascar's richest and most-successful teams, won't say which company assembles its synthetic oil and will only identify the scientists who work on its formula as "William the chemist," who's in charge of formulating the oil, and "Douglas," who used to work for NASA and is in charge of analyzing the team's worn engine parts under a microscope. "I don't want other teams trying to find out who these guys are," says Lake Speed Jr., who runs the team's oil program.
A couple of times a year, Mr. Speed gets a new shipment of experimental oil in nondescript black pails marked with code numbers. Mr. Speed tests it for 500 to 600 miles in actual Nascar racing engines powered by $2 million computerized simulators called dynamometers. Mr. Speed sends the used oil back to William and Douglas at the lab in clear plastic vials, along with some of the worn engine parts. Then the process starts over again until a new, improved formula is found.
There's no big commercial market for these oils. If they were used in a normal passenger car, experts say, their unfamiliar additives would destroy the catalytic converter. They also contain more sulfur, which makes them reek of rotten eggs.
Gibbs Racing says it makes up for some of its research costs by selling its own branded oil to amateur auto racers. The team's officials admit it's not the same oil the team's drivers use: Their formula is a secret combination of its retail brands. "I'm not going to give you the whole recipe," says Mr. Speed.
The two main purposes of motor oil are to make the engine run faster by lubricating all of its moving parts and to create a liquid film between metal parts that keeps them from rubbing against one another. The challenge in auto racing is creating oils that are strong enough to protect the engine while being slippery enough to allow the engine to reach higher speeds.
Motor oil has become increasingly important in Nascar, which tightly controls the technology in its cars and tries to keep costs down to lure more sponsors and more teams. Unlike the enormously complex and high-revving engines in Formula One, Nascar engines -- with eight cylinders, carburetors and push rods -- are not unlike those installed in a 1967 Chevy Camaro. Motor oil is one of the few areas where rich teams can use their money to get an advantage.
Most Nascar teams have one motor oil for long, 500-mile races and another for the single qualifying lap on Friday that determines their position on Sunday. (All this oil changing means each car will use 1,000 gallons of motor oil per season).
Qualifying oils are thinner and faster, while regular motor oils have more viscosity to protect engines longer. Before Talladega last season, Joe Gibbs Racing decided to try thinning out its regular racing oil with a mixture of qualifying oil to eke out slightly more horsepower. After running the experiment by Douglas and William, Mr. Speed got a warning from the two scientists. "You're scaring the hell out of us," they told him. The experiment worked, and one of the team's drivers, Kyle Busch, won.
Mr. Busch got most of the credit, but when asked whether he'd say the oil was a big factor, Mr. Speed responded "I would, because I'm the oil guy."
Wow.....good to know.....I have always wondered about those quarts of oil that say used by Nascar. Now I know it's definitely not that bottle :P
Great read.
:thumbsup:
Good find, and just because I am a NASCAR junkie, does not mean that I will follow what they dictate.
