1,445 Miles on Single Tank of Fuel
rabman5
 Orchard Lake, MI
Ford Fusion Hybrid Achieves 1,445 Miles on Single Tank of Fuel
Well, ladies and gentleman. After a challenging run, the fuel tank has finally been depleted. Ford's engineering team, along with the help of NASCAR driver Carl Edwards, achieved an amazing one tank run of 1,445 miles in a Fusion Hybrid after driving more than 69 straight hours.
The drive began 8:15 am E.T. in Mount Vernon, Virginia and ended at 5:37 am E.T. today in Washington, D.C. Drivers utilized various hypermiling techniques to achieve an average fuel consumption of 81.5 mpg and according to Ford officials, successfully demonstrated how real world drivers can double a manufacturers mpg ratings by adhering to the fuel saving philosophy.
Ford rates the Fusion Hybrid at 41 mpg city/36 mpg highway and estimates one tank of fuel can produce a 700 mile range all on its own. With this achievement, FoMoCo claims the world record for a mid-size sedan single tank fuel range.
If your itching to know, here are the hypermiling techniques Ford used during its record breaking run:
* Slowing down and maintaining even throttle pressure;
* Gradually accelerating and smoothly braking;
* Maintaining a safe distance between vehicles and anticipating traffic conditions;
* Coasting up to red lights and stop signs to avoid fuel waste and brake wear;
* Minimize use of heater and air conditioning to reduce the load on the engine;
* Close windows at high speeds to reduce aerodynamic drag;
* Applying the “Pulse and Glide” technique while maintaining the flow of traffic;
* Minimize excessive engine workload by using the vehicle’s kinetic forward motion to climb hills, and use downhill momentum to build speed; and
* Avoiding bumps and potholes that can reduce momentum
Source: Ford
Hypermiling works--until you p!ss off the folks behind you enough to stomp the s!@#$ out of you. :lol:
Most mags have been positive about the Fusion Hybrid and its performance.
Hmm, so on that principal we could be looking at Z4s/Z4Ms achieving 50-60mpg? Nah, doesn't sound like fun unfortuantely!
I've had the OBC showing 60-odd MPG when I've reset it on a 1 mile downhill section of dual-carriageway.
Would have been a great picture. Speedo showing 90 mph, board computer 60 MPG :D
I'll have to try to get a picture of it - although it'll have to be when I've got a passenger :oops:
