z4convertible
Does anyone have the pin out for the new style fan blower resistor. I have to cut the old connector off of the wiring harness and re-pin a new connector on, but not sure which wire goes on which number on the resistor.
And also whether a/c will work.Rockhopper said:So if your fan will only run on slow speed its very likely that your car is in transport mode and needs plugging into a scanner to either delete it or reset it. You can confirm by seeing if the heated rear window is also nor working.
I've never actually heard of a fan resistor failing.
So nothing works from the HVAC controls.z4convertible said:A/C nor heater will come on.
You need to find someone with suitable software. Scanner 1.4 (PA Soft) will reset it. Takes about five minutes, including plugging the laptop in.z4convertible said:I'm in Mississippi, so how do I change from transport mode
