Hi All,
I recently had my Z4 serviced at the local garage. I got in it for the first time today only to discover that when I drive it, the central info screen tells me the drivers door is open. I can also see the window hasn't gone all the way up like it normally does... i.e. drops a bit when you open the door, then closes up when you close it. I also note that the door open courtesy light is permanently on.
If I press the lock button nothing happens. If I lock the door manually with the key and then press unlock the door unlocks (but the window stays in the same position).
I've locked manually both sides and turned the light off again manually since the lock button doesn't seem to do anything.
I've got intermittent wipers that seem to randomly decide to stop working and locking wheelnuts done up so tightly that the garage broke the key trying to undo them and I've only just got a replacement new one.
I'm getting close to the end of my tether with it to be honest... Anyone got any ideas on what I can do to resolve?
thanks in advance,
Paul.
thanks in advance,
Paul.
