E85 Roof issue
hylandd
New member
 Salisbury
Hi, my E85 roof will not completely stow. It gets stuck on the plastic coaming. From edge of roof seems to be 2cm too far forward. Is there an adjustment I can make to the roof or is there a specialist near Salisbury, Wilts who could fix? All help appreciated .IMG_1587.jpeg
Quite common for the plastic trim behind the roll hoops to warp and foul the roof. Sometimes it can be persuaded back into shape. If not, the solution is to remove it.
If you are looking for a roof expert then your best bet is Alan (@Number5), who is in Bristol.
You're welcome to come and see me in Bristol if you wish but there's no adjustment on the roof itself. But we can have a play with the trim.
(But make it before October as I'm moving house !)
