20i Exhaust Tone
tomkinson36
 Surrey
Might be a stupid question but just had my car fixed after some dodgy spark plugs and i can now drive it properly.
I'm noticing a significant change in exhaust tone after about 30mins of driving.
I'm assuming this is supposed to happen just not sure why it takes half an hour? I would've thought the tone would come when the car is warmed up after about 10 minutes?
Much prefer the tone after as when the car is cold I cant hear much at all from the rear, is there anyway to make this occur sooner?
Any advice is greatly apricated, thank you.
Exhaust note shouldn’t be impacted by spark plugs unless you had a misfire or other running issues. They won’t have any impact on the volume or tone of the exhaust.
The tone of the exhaust when cold will be due to a number of factors, with the biggest being:
  • Acoustic performance of the metal components under temperature change.
  • Cold start and catalyst warm up - the fuel mixtures and timing are adjusted at cold start to speed up the catalyst warming. The exhaust is often louder and deeper during this period, combined with increased RPMs.
  • Exhaust valving - if a N20 or N54 equipped car, the exhaust valve will be open and closed under varying conditions. This will impact sound output and tone.
Hi Matt, thank you for the reply. I had a nightmare with a garage after a full service with bad plugs which were causing a misfire, first time I've been able to drive it properly
On the N20 there is a valve in the right (IIRC) exhaust tip. It's a flap, basically, and is controlled by vacuum pressure so can open and close when the pressure dictates.
There is something called a "golf tee mod" that many have done to keep the flap open all the time. It involves removing the vacuum tube to the valve and shoving a golf tee (or similar) into the hose.
