Gateway 300
paddy wright
Elite
 south yorkshire
I fitted the gateway 300 years ago and haven’t used it in a long time. I’m not sure if I’ve forgotten how to select it on the radio or if it’s died. It still has power going to it and I’ve checked the connections to the headunit. Any ideas to use it again.
it uses the CD setting from your radio, so switch to CD changer and off you go.
When you say a while back, I think you mean 2004 or so :rofl:
Ok, so you definitely have an issue with the unit or cabling then if it doesn't know it even exists. Where did you fit the unit, centre console?
Units in the glovebox. All wiring seemed ok- power goes to it as when you plug the phone in it charges the phone
