OK, this
is the final thought of the swap...
First thanks to
@Zedebee for recommending
@ivanchen1211 ,
I don't think I could do it better and I was afraid of damaging the MSV80
First Ivan
did the flash for me online, Then I went for
a short trip and he checked again for any error and everything was perfect.
The car
drives better, the power increased, very
noticeable. From 212 HP to 260 HP is
a 25%
increment, you easily can feel it.
So only
a swap without
a flash won't give you all 3.0 L power.
This was clear
to me once I did the swap and run the 3.0L N52, because before the swap, the engine used to rev to 900 RPM then to 600 RPM once warmed up. When I did the swap it barely
reached 700 RPM then back to 600 RPM. After Ivan
helped flashing the MSV80 with 30i, and
started the engine, RPM
jumped to 900 then to 600 after a minute or two, that's right...
The test drive went very well, and power is better but still you feel that little thing, after
accelerating harsh and
revving to 5000 or 6000 RPM then
releasing the pedal, you feel the engine
needs more air. Also feel this when
driving over 100
km/h.... So there was
a little
more to do, Ivan told me you need to do one more thing... He told me this from the beginning but we agreed to do first the flash and then this...
