Posting for future reference
A mate had 28B8 showing which wouldn’t clear. Idle was iffy and engine stumbling.
28B8 shows as mechanical stiffness in vanos exhaust side (or similar)
Changing the exhaust position sensor did nothing
Swapping for a different exhaust sensor did nothing too
A further Google suggested swapping out the piston that sits inside the vanos unit once the solenoid is removed- you can feel it with your finger
That was stiff to depress
Swapped for another spare unit and the code so far has not returned
Success I hope
Success I hope
