Vanne roof, bit of a less fun post..
Vanne
 Dubai
Hi guys…
So I opened the boot the other day, and tonight I’ve started looking at a few bits to do with the roof. The centre console roof buttons don’t light up, so I would have thought someone has messed with the wiring.. and lo and behold.. ofcourse they did..
Couple of not so nice pics.. :(
I guess that’s step one, figuring out where those wires go, looks like someone just came and cut them..
Would someone mind taking a few similar pics of the back of their car, so I can kinda see where those wires are supposed to go? That would be a huge help.
I wonder if they cut it, as to ensure the roof wouldn’t open again while driving.. ?
Anyways, looks like I’ve got my work cut out for me, but iam sure it’s not completely rocket science.. I won’t be tackling the roof at all until I have passed the RTA check, which I’ll do next week, but I am sure looking into this is a good start.
Thanks for the help guys..
NewTIS wiring diagram would show you what should give..too complex to take a simple screenshot here..
Thanks appreciate it, though iam a rather visual person, so for me a few pics of the space underneather the boot carpet will go a long way.
i did nick this one from one of the posts here and its already shown me that the purple socket is supposed to be empty, thats bloody great. A picture a little but further out would be awesome..20260303_121137.jpg
All strange, did you buy as non operating roof.
Looks like someone trying to fix by cutting and some temporary connections.
Was the pump replaced?
Or did someone just give up on it.
Takes some doing getting your head around what's going on when we had no info.
I had someone ask about my car and buying one.
I said don't unless your into DIY fixes.
Wiring diagram of sensors i put together for my own benefit.
Might not be 100% correct, have seen some H3 with brown and yellow wires. Might be later model car.
After wires connected i would replace the 2 salmon relays, cheap from BMW, common part.
Next a good obd reader is as useful and wanted as much as good fuel.
Yep bought it with the roof not working, (among a bunch of other stuff not working) same as the boot, it’s been closed/locked for at least 5 years the bloke reckoned. I do like a puzzle, but I just wish I knew for a fact that they haven’t stuffed with it further than cutting the wires in the boot. Either way I guess things will clear up a bit when I start on the roof. I got to fix some other stuff first for rego/mot.
Thanks for the help Bobbie
Just staring to gather some of the things I’ll possibly need for this part of the project, I am just wondering, the rear quarter windows, are they controlled by the roof module? As they are stuck in the up position, and I have no control over them, which hopefully will make sense as the roof module is disconnected.
Was the previous owner Edward Scissorhands?
On the bright side, at least you don't have that rusty boot to deal with.
And we’re onto the roof..
So this is the power plug onto the Hydrolic pump.. some smarty pants just HAD to cut the fucking wires, instead of just taking one second and unplugging the bloody harness.. how dumb..
Now not knowing much about anything, but I gather that this is red for power, black for earth, and then we have a dilemma.. I’ll assume that the 2 purple wires are for the pump going fwd or backwards.. they are exactly the same color wires, so how to know which one to hook up to which one? 50 50 chance?
Would be really nice to know …
Can’t fucking believe they cut that plug.. fuckin nitwits…
Is it possible to manually put the roof in a half open position then connect up the purple wires. It’ll soon be obvious if your 50:50 guess was correct or not.
Red - positive
Brown - negative
Violet - hydronic oil temperature, presumably it doesn’t matter which way they are connected.
Awesome, thank you... Oil temp eh.. Well it's bloody hot here atm lol..
So I plugged all that stuff in after connecting it up..
Zero..
Nada
So I gotta go further.. Nothing on the reader about the roof module
Right.. Need to dig further..
Plugged the new salmons in..
Nada.. Nothing..
Changed fuse 25 in the fuse box..
Nada..
Not even the green or red light light upon the push buttons... Which sends me to the controller...
OK need to.dig further... Man its getting soo hot outside..
Right inside now..
Pull a bit of the boot interior apart..
So bunch of cables not plugged into the roof module..
So, what happens when you plug them in?
I suspect it’s been unplugged because either, the pump was constantly running or the “bong of death” was constantly sounding.
Holy cows..
And this was stuck on the right hall sensor in the boot1786263468594832147670234638176.jpg
To this round sensor here, which I think is a hall sensor correct?17862635506634658348710828821363.jpg
Or does it need to be on there?
And the hydrolic motor isn't running, just red flashes on the down roof button.
Also the boot now closes properly , but the rear emblem doesn't open the boot. I have to jump it to open it .
lol okay I sorted the first question, that magnet thingy is supposed to be glued to the backside of the cover thingy that pulls down.. I guess the glue let go, I’ll glue it back..
So tackling the worst one.. a6a3 Hydrolic fluid temp sensor.. which actually has nothing to do with the Hydrolic fluid temperature, but how hot the motor is getting.
From what I’ve read on here and on the net over the last 24hrs, this code rather sucks hard.. it points to a busted motor. .. which I didn’t really wanna hear..
So you can buy just the motor bit, which is good, but it’s still around 700 quid and postage on top of that.. fark!
Anyone have any other ideas? Can I Hotwire the pump to test the motor still works, but even if it does and the temp sensor is rooted, then I’ll still be in the same boat..
other info on this is this is probably a result from previous guys that were working on this hot wired or used the motor too much and burnt either the temp sensor or the motor itself.. it’s not from water in gestation as I don’t think this car has EVER seen rain and only very sparkly been washed where they wash your car without us8ng hardly any water.
Zero evidence in the boot of water.. so yeah def an over heating issue I think..
So my other options than to buy a new motor?
I am starting with this code, as iam pretty sure this code stops any and all start/stop of the roof opening process, including the rear side quarter windows (mine don’t move at all)
Any advice would be much appreciated..
