00A698 rear end module open during driving fault
Kyle17645
Hi
I’ve got the constant bong / red roof symbol coming up , the fault is showing 00A698 rear end module open during driving fault
Just wondering if any one could point me in the direction of which micro switch/ hall sensor this is on the roof mechanism and I can look into anything obvious there,
I have searched the forum and found a few threads but there mainly for a 00A696 fault
Z4 35i 2009
Thanks very much
Kyle
I had saved lots of diagrams and pics but lost them all in a 3TB hard drive fail.
Found it.
I think it's the most useful piece of information.
Thanks very much ! Very helpful to have , although the fault Im getting isn’t listed there 00A698, I shall keep looking !
Thanks again (I’ll save this for future references)
You can see 2 are not given a code, could be your code is one of those.
Been looking at my car today, but i've replaced too much wire to see the old colours.
And red/brown is used a lot on the Hall sensors to first connector and black pair if a microswitch.
Make sure the roof protector is fully seated, left side has Hall sensor underneath where latches on the knob thing.
Make sure the piece of metal hasn't fallen off on the protector.
There is another thread live at present featuring the same (common) fault code for the roof.
Most likely a rear bootlid microswitch, but the above thread seems more complex, potentially, maybe, could be.
Thanks I’ve just come across that and gave it a read , great starting point for me to look into , thanks for the help
From my experiencing fixing my car the wires that break in the roof are the one's wrapped in tape.
I think the glue on tape reacted with the wire insulation.
Other wires not wrapped seem fine.
