Afternoon folks! Hoping someone might be able to help or make some suggestions as to what my issue might be. I had my phoenix yellow e86 si coupe in to get new brake lines all round for the MOT and shortly after I started getting the traction control light flashing, causing kangarooing. At first this only happened once in a while but got worse. Local mechanic said there was rust on the sensors and tried to clean them to solve but to no avail. It then went back in and had the drive shafts replaced last week however, much to my dismay, this has still not solved the problem.
I have read some other threads on TC issues but not identical to my own. Any suggestions greatly appreciated.
Thanks!
Thanks!
