Has anyone had an issue with the overflow bottle leaking at the o'ring on the lower nipple? I've replaced the bottle and now it leaks at the second o'ring. one of the two nipples on the bottom of the bottle has a retaining clip the other doesn't. It leaks from the one that doesn't. I thought it was leaking from the drain cock and tried to tighten it and it snapped so I replaced the bottle housing mount bracket. Still the same issue. Any tips on getting the bottle to seat properly in the housing? Im thinking of changing the bottle back to see if the issue follows.
