30i roof issues
Chalont
New member
 London
Hi all,
Been having roof issues on my 2011 30i. This started a few days ago as random roof warning lights and a beep, but has now progressed into full roof malfunction.
Randomly when driving, or returning to car after leaving it parked, the roof open button LED will be flashing red and will also have an error symbol on dash, along with a constant beep which is driving me insane. The roof open/close is very hit or miss so decided to leave it closed and empty the boot in case it gets locked out.
Reading the following error codes:
A698
A69E
A6A4
A693
A689
A68C
A698 points to a potential microswitch issue on boot, have resistance tested both left and right switches and they function fine. Also inspected cabling on right side of boot hinge, all looks okay.
A68C is passenger side hall sensor issue, this has actually just popped up today, yesterday it was only A698.
I believe all other codes are symptoms of the two above?
Is this likely to be just a case of broken cabling in a couple places? It seems strange that hall sensor code appeared a day after microswitch code.
Really appreciate any help as quite stuck with this.
Thanks!
Most likely your bootlid microswitch (es). Corroded internals can cause random making and breaking of the switches due to dodgy connections.
The other codes are most likely because of the microswitches.
Change both sides, not just one. They are still relatively cheap to buy from BMW (although not as cheap as they were IIRC) and are a fairly easy DIY job. There are a few very useful guides to changing them on here.
Hi all,
A698
A69E
A6A4
A693
A689
A68C
Thanks!
Unlikely to be damaged microswitches, they are rock solid and long lasting - hall sensors not so much.
Have a watch of this, the channel is excellent and a LOT of garages subscribe to it for assistance, iuncluding my BMW Indy.
Looking at your fault code pattern and progression, this points strongly to coupling lock microswitch failure rather than wiring issues. Let me explain why:
Primary Diagnosis: Coupling Lock Microswitches
A698 is the key fault code
— this indicates the coupling lock microswitch system (Vol 3, Ch 10.4). While your resistance testing shows the switches responding, this doesn't rule out the most common failure mode: internal contact corrosion and hardened rubber components within the switch housings (Vol 3, Ch 10.4).
The failure mechanism is subtle: "Corrosion develops on the electrical contacts inside the switch body, and the green rubber components within the housing harden with age. The result is intermittent operation: the switch works sometimes, fails sometimes" (Vol 2, Ch 4 — Task 3).
Why Your Testing May Be Misleading
Your resistance values showing ~550Ω unpressed and ~2,700Ω pressed suggest the basic switching function works, but intermittent internal corrosion can pass a static resistance test while failing under dynamic conditions — temperature changes, vibration, or repeated cycling (specialist diagnostic guidance in this bot's knowledge base).
Code Progression Pattern
The appearance of A68C (passenger side Hall sensor) a day after A698 follows a documented pattern: "When the coupling lock switch fails to confirm boot closure within the expected time window, the CTM logs a Hall sensor timeout — not the switch fault that actually caused it. This is the root cause of the 'I replaced an expensive sensor and nothing changed' experience" (Vol 2, Ch 4 — Task 3).
Recommended Action
Replace both coupling lock microswitches simultaneously
  • Left: 54377228585 (~£16)
  • Right: 54377228586 (~£16)
  • Always replace as a pair (Vol 2, Ch 4 — Task 3)
The specialist guidance emphasises: "Attempting diagnosis without replacing both switches simultaneously is a false economy: if one has reached the point of failure, the other is close behind" (Vol 2, Ch 4 — Task 3).
Diagnostic Confirmation Test
Before replacement, you can verify this diagnosis using the jumper wire technique: with the car in trunk service mode, place a jumper between CTM connector pins 9 and 11. If the roof then operates correctly, "the coupling lock switches are confirmed as the source of the fault — no other component is implicated" (Vol 2, Ch 4 — Task 3).
Your 2011 car is now 13 years old — well past the 10-year proactive replacement interval recommended in the maintenance schedule.
Sources: [Vol 3] Chapter 10 — Retractable Hardtop Faults — 10.4 Coupling Lock Microswitch and Hall Sensor Failure · [Vol 3] Appendix D — Supplementary Chapters (Consolidated 16 Apr 2026) — Decision tree — roof system faults · [Vol 2] Chapter 4 — Retractable Hardtop — Roof System Components and Their Functions
Thank you everyone for your replies!
Roof issue has now been resolved, the issue was a snapped wired in the rear window shell drivers side, aligning with the error code A68C.
All other error codes disappeared after this and roof is opening/closing normally.
Had the A698 code return, I understand this is likely a microswitch issue. The A68C issue seems to have been unrelated.
Are these the two microswitches at the rear of the boot lid, or the ones further into the boot which can be accessed by putting into service mode?
Thanks for the video javis20, the right side microswitch was exactly the issue!
Picked up replacement from local bmw parts shop, price of £130 for a tiny switch nearly killed me but was no other choice as previous switch was testing faulty with multimeter.
Roof all working well now and back to enjoying the 30i!
  • Like
Reactions: B21
Last time I bought roof microswitches they were £16 a side from a BMW dealership (2022 IIRC). I blame Trump and Stammer in equal measure. :mad:
Судя по характеру и последовательности появления кодов ошибок, это убедительно указывает на неисправность микропереключателя блокировки соединения, а не на проблемы с проводкой. Позвольте мне объяснить почему:
Первичный диагноз: Микропереключатели блокировки соединения.
Код ошибки A698
указывает на неисправность системы микропереключателей блокировки (том 3, глава 10.4). Хотя проверка сопротивления показывает, что переключатели реагируют, это не исключает наиболее распространенный вид неисправности: внутреннюю коррозию контактов и затвердевание резиновых компонентов внутри корпусов переключателей (том 3, глава 10.4).
Механизм отказа довольно сложен: «На электрических контактах внутри корпуса выключателя развивается коррозия, а зеленые резиновые компоненты внутри корпуса со временем затвердевают. В результате возникает прерывистая работа: выключатель то работает, то выходит из строя» (Том 2, Глава 4 — Задание 3).
Почему ваши тесты могут вводить в заблуждение
Значения сопротивления, показывающие ~550 Ом в ненажатом состоянии и ~2700 Ом в нажатом состоянии, указывают на то, что основная функция переключения работает, но периодическая внутренняя коррозия может пройти тест на статическое сопротивление, но выйти из строя в динамических условиях — при изменении температуры, вибрации или многократном циклировании (подробные рекомендации по диагностике см. в базе знаний этого бота).
Шаблон последовательности кода
Появление ошибки A68C (датчик Холла со стороны пассажира) на следующий день после ошибки A698 соответствует задокументированной схеме: «Когда переключатель блокировки сцепления не подтверждает закрытие багажника в ожидаемый временной интервал, CTM регистрирует тайм-аут датчика Холла, а не неисправность переключателя, которая фактически вызвала это. Это основная причина ситуации, когда «я заменил дорогостоящий датчик, и ничего не изменилось» (том 2, глава 4 — задание 3).
Рекомендуемые действия
Одновременно замените оба микропереключателя блокировки муфты
  • Слева: 54377228585 (~16 фунтов стерлингов)
  • Справа: 54377228586 (~16 фунтов стерлингов)
  • Всегда заменяйте парами (том 2, глава 4 — задание 3)
В рекомендациях специалиста подчеркивается: «Попытка диагностики без одновременной замены обоих переключателей — это ложная экономия: если один из них вышел из строя, другой вот-вот выйдет из строя» (том 2, глава 4 — задание 3).
Диагностический подтверждающий тест
Перед заменой вы можете проверить этот диагноз, используя метод с перемычкой : в режиме обслуживания багажника автомобиля установите перемычку между контактами 9 и 11 разъема CTM. Если после этого крыша будет работать правильно, «подтверждается, что источником неисправности являются переключатели блокировки сцепления — никакие другие компоненты не задействованы» (том 2, глава 4 — задание 3).
Вашему автомобилю 2011 года выпуска сейчас 13 лет — это значительно больше, чем рекомендуемый в графике технического обслуживания 10-летний интервал плановой замены.
Источники: [Том 3] Глава 10 — Неисправности выдвижной жесткой крыши — 10.4 Неисправность микропереключателя блокировки сцепления и датчика Холла · [Том 3] Приложение D — Дополнительные главы (сводная информация от 16 апреля 2026 г.) — Дерево решений — неисправности системы крыши · [Том 2] Глава 4 — Выдвижная жесткая крыша — Компоненты системы крыши и их функции
Добрый день. Пожалуйста, помогите мне найти, где я могу купить эти датчики за 16 фунтов стерлингов. Дайте мне ссылку, пожалуйста.
И ещё, где я могу достать книгу и электрическую схему для этого автомобиля?
Well I can trump the £130 above as I paid £168.05 each 😲
Bought from LLL Parts and assuming posted from Germany (and forwarded to their UK branch to deliver). I did first try a BMW online dealer but items were coming back as out of stock. Price hike is inline with what @RobbiZ4 reported back in March I guess but still defies logic.
It is unfortunately getting to the stage where using the forum to search for roof-related issues results in waay too many tangential hits. But I did (eventually) find this thread with correlated entry "If your roof opens , folds into the boot successfully but the windows fail to raise and the boot won't open or the roof closes and leaves the rear window cam shell on top of the roof and the windows fail to raise. ...........this is likely to be a faulty boot switch micro sensor .items 4 and 5" - which was exactly my issue. For what it's worth, BimmerLink failed to provide a single related fault code.
Using the 3 minute video by @javis20 for which I am appreciative of, all told, it translated into a 4 hour task. Biggest PITA was attempting to drill the first set of screws out. A good half hour plus there making little headway before I resorted to a more agricultural approach. Long nosed pliers to distort the aluminium plate section on the switch enough to create a small gap, then inserting a large head flat screwdriver to prize it away from the screws bearing in mind plate is only very thin and flimsy. So then just a couple of minutes work to do same on the other side.
Seems a lot of few years into manufacture cars have this problem.
Wonder if there was a batch of faulty switches fitted. My 2009 car no problems.
One poster showed a picture of a loose resistor inside the switch.
Looked like the surface mount resistor might have had a dry joint.
