Expanding tabs holding front bumper on inside of wheel arch
Brazilianhipster
 CV35
Hi,
Is anyone able to tell me which part number these plugs are? I've looked on various websites, but the part image doesn't look like the plugs I've pulled out!
Thanks!
The plugs in the second and third picture aren’t the ones that are supposed to be there, although the first picture looks correct.
OEM part number is
07147172274 or 51717007296​
Pre and post 03/2007. Either should work. You could use a different style of expanding rivet if you like, e.g. one with a pin-head rather than a “push-through”, but generally speaking OEM (or a copy) is best.
