I have been trying to install an MMI box (Andream) in my 2016 35i and have run into an issue. For reference, I've been following this DIY video:
I get to about 15:10 in that video, i.e., connected the MMI box to the head unit and testing to see if it works before reassembling. The result, nothing in idrive functions. The screen doesn't pop-up like it used to and none of the idrive buttons or head unit buttons do anything. Car starts fine and everything else appears okay, but no idrive. I thought I had a bad box or cables or something so I reversed everything and reconnected in the original configuration. Still nothing. Now I'm worse off than before as I don't have an idrive, radio, or anything sound system or nav even though I'm back to the connections before I did any disassembly.
Anyone have any ideas on how to troubleshoot this? I checked the fuse on the head unit itself but that appears to be good. Any other fuses I should check? Is there an idrive reset procedure or something that needs to be done? I've exhausted my capabilities and knowledge at this point.
FWIW, my e89 has the knee airbags integrated into the glove box, which turns out to be a real PITA for disassembly, but can't think of how that matters for anything else.
