I think I read somewhere that in theory you could 'double up' the spring pads, so one on top, and one on bottom of spring? Don’t know if that is correct?
I was thinking maybe both, although the E9x top mount seems to be a lot thicker and thus removing the need for reinforcement plates? But as mentioned earlier. I’d prefer to raise the car between the spring perches to reduce compression and increase travel of the B4 shock.Adding 2.5mm with either the E9x mount or reinforcement plate will help and might fully elliminate it.
