So where is the problem?Yes, only when mechanically completely locked, trunk lid as well as the rear roof shell.
As said several times:Why, even before starting the car, flashing light for the roof.
No fault code!!!!
In both cases all 4 named microswitches have to be "locked".Cause it's currently neither completely opened nor closed. It's in-between.So why it is flashing ...
I noticed some oil on top of front roof shell.
Now I can see oil dripping from the right piston but not sure if it is the connection, hose or the piston itself.
Pretty sure a broken hydraulic hose.
In addition, INPA presents a view of preconditions.
That might be just a configuration detail.
There is a config file called INPA.INI, where the different models can be assigned to the INPA main view.
These are the required steps:
Z4 E89 Kofferraum über INPA öffnen Lösung
Hallo alle zusammen, das ist mein erster Beitrag hier im Forum. Ich habe mir vor ein paar Wochen einen Z4 3.0i E89 zugelegt und direkt mal im Forum nachgeschaut was es so für Probleme geben kann vor allem bzgl. dem Hardtop und Kofferraum. Die Problematik, dass der Kofferraum nicht mehr...www-zroadster-com.translate.goog
I did check the level, but will check it again.View attachment 288147
What about this hydraulic topic:
- Enough hydraulic oil in the pump's reservoir?
I wish I did not took it to that workshop, used jack to lift the shells from the trunk!!!!
- Magically solved?
I tried but could not reconfigure INPA, but I will try again after uninstall INPA and follow the steps you refered me to.Another question:
Were you able to reconfigure INPA to get access on the E89?
Generally correct, butIs it possible that the pump cannot raise the pressure due to either not enough oil or leaks in the hose?
a) you can check the level visually by just lifting the pump and placing it on the battery. There are min/max markers on the reservoir.
Febi "ZHM" is the correct oil if not sufficient.
They are both new. I then reinstall old ones but no success so fit again the new relay'sb) The two salmon relays are responsible to start the pump's motor. If they get not activated by the CTM,
I installed INPA and access the CTM.b) The two salmon relays are responsible to start the pump's motor. If they get not activated by the CTM, missing oil is a secondary problem.
Yes, it's way too much!It is over filled!!!! Should I empty untill it reach maximum level...
New relays are ok, just read it in an older answer from you.They are both new. I then reinstall old ones but no success so fit again the new relay's
Yes, they are uselessI know you will say these messages are useless
Great news, congratulations!!! Even it's in German, it may help.I installed INPA and access the CTM.
| German | English | عربي - Arabic |
| Relais | relay | تتابع |
| Ventil | valve or solenoid | صمام أو ملف لولبي |
| Pumpe | hydraulic pump | مضخة هيدروليكية |
| Mikroschalter | microswitch | التبديل الجزئي |
| Hallsensor | hall sensor | مستشعر القاعة |
| Gepäckraum-abdeckung | luggage partitioner | مقسم الأمتعة |
| Geschwindigkeit | speed | سرعة |
| 4 Seiten | 4 pages | أربع صفحات |
| Checksumme | checksum | المجموع الاختباري |
| auf | open | يفتح |
| zu | close | يغلق |
| tbc |
Ok, that indicates the CTM has recognized a blocker.What I noticed that when I press the open and close switches at the console, no activation to the salmon relays
What is TIS?Do you have access to TIS?
German English Relais relay Ventil valve or solenoid Pumpe hydraulic pump Mikroschalter microswitch Hallsensor hall sensor
There is a "state of prerequisites" page available in INPA, in German " Status Sperrbedingungen" according to the following example:
If there is a green arrow on the lower right as in the upper example, you can browse through several pages with the page down/page up keys on the keyboard. Prerequisites aka "Sperrbedingungen" has 3 or 4 pages. If there is any black bulletpoint, its' a blocker.
Yes, this first(!) page is without a blocker.It does not show anything?
| German | English | Arabic - عربي |
| Status Interne Zustaende | internal states | الدول الداخلية |
| Fenster | window | نافذة |
| Fahrertuer | drivers door | باب السائقين |
| Beifahrertuer | passengers door | باب الركاب |
| Geöffnet | opened | مفتوح |
| Geschlossen | closed | مغلق |
| Kein Status | no or unknown status! | لا يوجد وضع أو وضع غير معروف! |
| Aussen-temperatur | outdoor temperature | درجة الحرارة في الهواء الطلق |
| Fenster hinten [Fahrer / Beifahrer] | rear window [driver/passenger] | النافذة الخلفية [للسائق/الراكب] |
| hinten | rear | مؤخرة |
| Fenster öffnet | window is opening | النافذة تفتح |
| Fenster schliesst | window is closing | النافذة تغلق |
| Fussraummodul FRM3 | footwell module FRM3 |
I did checking in the morning before the sunrise so I can see the screen, in winter sun is so bright here.I'll be off for the next 2 hours.
OK, these are the prerequisitesIf there is a green arrow on the lower right as in the upper example, you can browse through several pages with the page down/page up keys on the keyboard. Prerequisites aka "Sperrbedingungen" has 4 pages as mentioned on the top. If there is any black bulletpoint except the almost last one ("checksum/Checksumme"), its' a blocker.
No we did not, when running it, it shows an error but I keep pressing proceedDid we already discuss / check the 4 window states?
Infos can be found in JBBF as well as in FRM3.
Here is mine through CTM
Here is mine through JBBF
I download the repair manual, about 7000 pages but for Z4 2013Do you have access to TIS?
