We don't have the right pulley config do we?
Going hydraulic! And a coding query for you experts
- Darkangelv2
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
- Steve84N
We have the N52 in a pre LCI e91 330 and whilst it's hydraulic steering the pump is electrically driven. It was the beginning of the end but does offer small improvements in mpg as the pump isn't active when not required. I really wish this as far as they went as it seems the best of both worlds but apparently a couple of mpg is worth sacrificing feedback on the most important part you constantly interact with...MACK wrote: ↑Mon Sep 04, 2017 12:01 pm If they don't I think the non active steering version of power steering on the e90 330i with the n52 engine is a purely mechanical system. So in theory the n52 pump and reservoir will be useable so if you can mate that to the e46 rack/pipework it should work. However the only real issue I can think of is the pressure from the n52 pump may differ to the m54 making the steering feel heavier/lighter.
C63 AMG Estate 6208cc
- adam1985
Just been looking on realoem and google image searches and looks to me like there are a couple of models with N52 engine and hydraulic PAS including e87 130i, some E60 models and some e90 models. Not sure is everything would work but I guess you would need e46 rack and e60/e90 pump, reservoir and aux belt.Darkangelv2 wrote: ↑Mon Sep 04, 2017 12:58 pmWe don't have the right pulley config do we?
Not sure if its that simple?! probably not
57 BMW 3.0si sport Coupe, Carbon Black, Bilstein B12 Suspension, CSL reps & style 339s for winter - Current
10 Skoda Fabia mk2 vRS, Rallye Green, Black Roof, Black Gigaro Alloys - Gone
08 Fiat Grande Punto Dynamic Sport, Red, Dual Sunroof - Gone
- Steve84N
Did you not read my post, the e90 (and therefore those others mentioned too most likely) use hydraulic steering with an electrically driven pump.
- adam1985
I was looking for aux belt driven pumps not electrically driven
- MACK
Just to further clarify what I said earlier, the optional active steering versions of the e9x as well as 1/x3 n52 models have pumps that are belt driven with electronic control. Where as the standard non active steering versions are purely old school mechanical. Worth noting that the active/non active models also have an entirely different pas res from the active steering version as well.
Silver 05 3.0i SE
White E89 20i M Sport
I know this is an old topic but hope you are still able to respond to questions. I was interested in your statement in your earlier thread in this Topic - 'So I detached the motor and removed the pinion', I have had my motor out a couple of times (unsuccessful repair) so familiar with motor construction, when you say 'pinion' are you referring to the motors worm geared shaft, if so, exactly how did you remove it ?
- Sidewaze Samm
More likely to get a response if you notify the OP by including actual quote from the post referenced. But then it appears mjennings23 hasn't been active since April...portculisz4 wrote: ↑Wed Aug 03, 2022 2:28 pm I know this is an old topic but hope you are still able to respond to questions.
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
Thanks for the suggestion, I stumbled across his old thread through numerous searches, I did include the quote in inverted commas, it was a shot in the dark that he would be still be monitoring the forum but nothing lost in trying.
