What have you coded with Carly
enzed4
Post by enzed4 » Thu Jun 15, 2017 11:30 am
I did the same as Mike, (removed the ones I didn't do):
Ducklakeview wrote: Wed Jun 14, 2017 9:58 am I've done, on mine;
Boot locked when car locked (ie internal release deactivated)
One touch up on pass window (for some reason most E85's don't have it enabled)
Indicators flash when locked/unlocked
Windows continue opening/closing when ign turned off
Windows work with door open
Windows continue working for a time when ign turned off
Wipers go to intermittent when you stop moving
Wipers continue their sweep when ign turned off
Mike
Disabled the annoying 'reminder' that goes off if you open the driver's door with the keys off but still in the ignition. Meant to stop you leaving the keys in the car and walking away, but just makes it sound like every Jap import I've ever owned.
Coded DRL's, but as the halos are wired to the sidelights I can't see any way to get them turn off when the headlights come on.
Didn't code foglights to high beams as it's illegal here (and why would you want them on with the high beams anyway? Are the high beams that bad they need help from the fogs?? :?).
Also used the app to check and clear the ABS/DSC error codes after getting the pump repaired.
Very handy bit of software and worth the price I reckon. Added bonus is you can program other BMW's with it, so you can share the coding/diagnostics love with your neighborhood BMW friends :)
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
Savage
Post by Savage » Fri Jun 16, 2017 10:10 pm
Coded the Roof Open/Close from the key
Audible lock/unlock
One touch up on passenger window
Electric windows with ignition off (1 minute)
Wipers continue on ignition off
Roof continues when driving off
Tomsdad
Post by Tomsdad » Wed Jun 21, 2017 7:19 pm
Someone tell me to stop carlying around.
I have tried the brake force activation to give me doughnut rear brake lights.
Brake lights and rear tail lights come on together.
Anyone know if this is not legal?
2007 3.0 Si
Montego Blue
Manual
Chris1981
Post by Chris1981 » Thu Jun 22, 2017 2:07 pm
Laws appear to date back from 1989 so I'd think as long as they are red and the rear lights still work independent of braking you'll be fine!
http://www.legislation.gov.uk/uksi/1989 ... tents/made
All I've coded on my Coupe is the boot now unlocks on first push of button with no delay and the windows work without keys in ignition and continue after you open the door... coding angel eyes as DRL's is pretty cool looking if you have angels! I don't... :?
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
Online
kis
Post by kis » Tue Jun 27, 2017 11:02 pm
Alarm chirp when locked, but not unlocking
Drivers comfort entry (window lowers when door opened after double tap on unlock - Handy for getting in when space is tight)
As above, but window then closes when door closed
Doors auto lock @ 2mph
Hazards double flash rate
Think that's my list complete...
Mike
Coding options which I've done (in addition to Mikes list). No particular order.
1. Number until headlight cleaning - 9th interval
Clean the car frequently anyway and just ends up using up my washer fluid!
2. Comfort open using remote
Windows go down on fob unlock (and hold)
3. Comfort close using remote
Windows close on fob lock (and hold)
4. Automatically lock vehicle
If I've unlocked the car by mistake and not opened a door the car locks itself again after about a minute
Played around with brake force in Carly but never got it to work, let me know if you've done it! :thumbsup:
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
Ducklakeview
Post by Ducklakeview » Tue Jun 27, 2017 11:26 pm
Oh and Jingle coded my rear donut brake lights :D
Mike
Chii
Post by Chii » Sun Jul 30, 2017 6:28 pm
Tomsdad wrote: Tue Jun 13, 2017 6:00 pm Thought it might be an idea for us to share what we have coded with Carly. Just so we all get the maximum from it.
I have just done mine for the first time.
1. Roof close on the keyfob
2. Roof open/ close while driving slowly
3. Central locking activated on drive away
4. 3 flashes when nudging indicated stalk
5. Audible and visual indication when car is unlocked. Shows when you are in remote keyfob range
6. Front fogs come on with high beam
Hi all,
I can't manage to get number 6 working. The fogs with high beam.
I managed to get them to turn off with high beams but not to come on.
The option within carley is called 'front fog lights with high beams' which sounds like the right place to be. But in the description it says 'front fogs are automatically turned off when activating high beams'
Am I looking in the wrong place?
Cheers,
36valley
Post by 36valley » Sun Jul 30, 2017 7:31 pm
This may seem a little odd but can Carly program the Speedo to be illuminated all the time, not just when the headlights are on?
Online
kis
Post by kis » Sun Jul 30, 2017 10:58 pm
Don't think so. Not with Carly anyway, it's really good but limited. You'll need NCS or something like that. They're a bit more advanced... more options and the like :thumbsup:
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Ted75
Post by Ted75 » Sun Jul 30, 2017 11:28 pm
This is my kind of thread! :D
Just need the car to play with it on :oops:
2003 silver 3.0i :driving:
36valley
Post by 36valley » Mon Jul 31, 2017 7:47 am
kis wrote: Sun Jul 30, 2017 10:58 pm Don't think so. Not with Carly anyway, it's really good but limited. You'll need NCS or something like that. They're a bit more advanced... more options and the like :thumbsup:
:( Ok, thanks.
Claret
Post by Claret » Sat Mar 17, 2018 7:59 pm
But why..............are all these REALLY necessary?
Online
kis
Post by kis » Sat Mar 17, 2018 10:05 pm
Are all optional extras necessary when you buy brand new? Coding options lets you customise YOUR car to suit YOU. You definitely don’t need all of them. But some of them just make things better, easier or more convenient :)
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Gstew89
Post by Gstew89 » Sun Mar 18, 2018 10:26 am
Are you guys all using the Carly app on your mobiles? Is the bluetooth connection just as good as a cabled connection? Also is the coding pretty straight forward to complete?
Tomsdad
Post by Tomsdad » Sun Mar 18, 2018 10:36 am
Yes and yes
2007 3.0 Si
Montego Blue
Manual
