Custom Cruise Control Loom
Are you still doing the wiring loom if so can I buy one please ?
05 z4 3ltr se is us
Onlinesrhutch
- Moderator
Yep, need details of the car. Starting to make more soon.
Tidy . Mine is 2005 3ltr se auto
Vin num wbabt52010lt02743
Anything else . Money up front?
05 z4 3ltr se is us
Hi. I bought a loom (N52) at Zedfest. Grateful if you can send me the instructions.
Thanks, Chris
Thanks, Chris
Z4 Coupe 3.0 Si Sport
Eibach Springs and Sports Exhaust
Hi srhutch
I note from the original post you also do fitting - do you have stalks yourself ie all the parts needed?
also Where abouts are you located?
Z4 now sold
Current - M235i
Current - M235i
Onlinesrhutch
- Moderator
Based in East Sussex. You would need to supply the stalk, the rest is just the loom and cutting of the lower cowl.
Almost done fitting it
Spent some time this afternoon taking out all kinds of trim to route the blue wire behind, fitted the cables to the LCM, and even fitted the stalk already.
There's just one tiny but crucial detail left: How do I get the pin on the blue wire into plug X6021? This one:
On the LCM side it was quite straight forward, albeit a bit fiddly. Take the large connector and slide out the two blue/brown pieces and then press the tiny latches to release individual pins. And then just slide in the new pins.
Any hints? I guess I need to take the plug apart a bit to be able to fit the new pin, but how do I do that without breaking any tiny plastic bits?
Z4M Coupe
Spent 5 more minutes on it earlier today and it's all done and working now.
Thanks a lot for making the loom, much cleaner than cutting into wiring!
The X6021 connector just had a funny flip open mechanism:
Z4M Coupe
Onlinesrhutch
- Moderator
Sorry ah- only just seen this, but glad you got it sorted.
Trying to work out what connector you pictured above
bradz fitted his today, so that's 2 of the 6 supplied it Shepshed in and working.
Ha, that one's just to confuse you
It's from a different car (E39 I believe) but nicely illustrates the same flip open mechanism. Comes up if you google for X6021.
And cruise control is still working like a charm!
Z4M Coupe
Onlinesrhutch
- Moderator
Ok, yes the is a smaller flip panel on the S54. I'll update the instructions to make that clearer.
- Darkangelv2
Hi Srhutch
Can you add me to the list for an N52 loom please?
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
Hey Srhutch,
How has production been coming along? I've got my stalk all ready and waiting for your loom to do the install...
Onlinesrhutch
- Moderator
I've sold the first batch and starting to make the second batch of 10. I'll be in touch soon with those who have expressed an interest.
Also have another version using Posi-Twist connecters which some might prefer. More details on that soon.
