Rattle in neutral, clutch disengaged
ChillZ4
Post by ChillZ4 » Thu Mar 12, 2009 4:13 pm
Is this normal, sat in neutral with the clutch disengaged I can hear a rattle, this goes away when the clutch is depressed. I no about this noise when you turn off in neutral but is it normal when idling in neutral?
06 BMW Z4 3.0si Roadster
Biggsy
Re: Rattle in neutral, clutch disengaged
Post by Biggsy » Fri Mar 13, 2009 6:22 pm
Sounds like the thrust/release bearing has gone.
Alpine white 2011 S23 M SPORT,
ChillZ4
Post by ChillZ4 » Fri Mar 13, 2009 6:40 pm
Sounds expensive, its out of warranty in a week!!!
gannet
Post by gannet » Fri Mar 13, 2009 6:50 pm
ChillZ4 wrote:Sounds expensive, its out of warranty in a week!!!
best get to your dealer then....
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded :D
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
ChillZ4
Post by ChillZ4 » Fri Mar 13, 2009 6:53 pm
It was in the other day for this reason and they reckon they couldnt hear anything! I wont be able to get the car in till after the warranty has gone!
Biggsy
Post by Biggsy » Fri Mar 13, 2009 6:56 pm
Supply your own clutch plate and get them to fit it for free while they are doing the bearing,
Or even better see if you can get them to put a complete clutch kit in it!, :thumbsup:
scottyD
Post by scottyD » Thu Mar 26, 2009 7:49 pm
I had the dealer check this noise out when I was there last for Inspection 1. They said it was normal for the clutch/transmission in the E46 3 and Z4 series....
Who knows if it's really okay or not, but my dealer wasn't going to do anything more with it. Guess I'll find out down the road - 45k mi now and still going strong
Smokin
Post by Smokin » Thu Mar 26, 2009 7:53 pm
It's ok scottyD-- mine does it too, especially if the car is stopped on an incline, in neutral, clutch engaged. My service adviser is a pretty smart cookie and he called it "gear rattle". He says his E46 M3 does it as well. There are two counter-rotating shafts in there in very close proximity. Try it, the noise goes away if you depress the clutch pedal while still in neutral.
2007 3.0si coupe, sapphire black, saddle brown extended leather, heated M seats, premium package, sport package, Carver, light poplar wood trim, xenon, headlight washers, 6 spd. Member BMWCCA, ZSCCA, Homecoming 08 Pirate.
scottyD
Post by scottyD » Thu Mar 26, 2009 8:00 pm
Yeah, same here - noise gone when you push the pedal down. I noticed it being worse after driving for awhile compared to just after startup.
My advisor said something about a clutch throw-out bearing being worn, but I wouldn't consider him a smart cookie, so who knows. Thanks for the info.
IK.
Post by IK. » Mon Mar 30, 2009 5:10 pm
Bringing this to the top, as I have the same thing... Mine has 16 months warranty left, so should I get it down the dealer for a FREE fix? (14k miles). It rattles constantly when in neutral, but if you depress just a tad, it rattles really loudly. Can also hear it when driving.
Currently car-less!
Previous: Z4 3.0si Coupe & Z4M Roadster
Plus a few others!
Smokin
Post by Smokin » Mon Mar 30, 2009 5:46 pm
IK. wrote:Bringing this to the top, as I have the same thing... Mine has 16 months warranty left, so should I get it down the dealer for a FREE fix? (14k miles). It rattles constantly when in neutral, but if you depress just a tad, it rattles really loudly. Can also hear it when driving.
That sounds different--what I was talking about was a definite rattle that goes away when clutch pedal is depressed.It doesn't increase in intensity nor can you hear it when driving. Have your dealer check it out for sure.
IK.
Post by IK. » Mon Mar 30, 2009 5:57 pm
But they may charge me if it's not a warranty issue...?
The noise goes away when fully depressed. The sound only gets louder from the top 5% of the pedal travel (lightly touching the pedal, basically)
Currently car-less!
Plus a few others!
scottyD
Post by scottyD » Mon Mar 30, 2009 6:00 pm
I see what he's saying....I think I have similar symptoms....
Smokin
Post by Smokin » Mon Mar 30, 2009 6:05 pm
IK. wrote:But they may charge me if it's not a warranty issue...?
The dealer shouldn't charge you-it's under warranty still. Better to check it out now than let a part fail.
ChillZ4
Post by ChillZ4 » Mon Mar 30, 2009 6:09 pm
I think this is normal.
