Quantum Remap on E89 20i
Pooltee
Post by Pooltee » Wed Sep 02, 2020 9:11 am
Pbondar wrote: Fri Aug 28, 2020 9:23 am Pooltee, if you can find an understanding MOT station you should go for a de-cat rather than a new exhaust system...you’ll get a distinct sound that doesn’t sound unpleasant plus better spool up time and slightly more BHP..
I am very tempted to try this Pete. Have you got a link for where you got your decat pipe from? I was going to go with the ultimate bhp one, but from what I remember the for wasn’t exactly straight forward.
Paul
2013 Z4 20i sDrive.
Remapped, and currently “interior” rattle free.
Early midlife crises and so far loving every minute of it!
Pbondar
Post by Pbondar » Wed Sep 02, 2020 9:44 am
Pooltee wrote: Wed Sep 02, 2020 9:11 am
Paul
https://www.vr-speed.com/vrsf-n20-catle ... -e89.html/
ieatanimals
Post by ieatanimals » Tue Sep 22, 2020 7:54 pm
Pooltee wrote: Fri Aug 28, 2020 8:15 am
ieatanimals wrote: Fri Aug 28, 2020 2:54 am Hi. Just had my 1.8 Z4 remapped by A1 Remaps in Hull. I did get a custom stainless exhaust fitted by OLDSCOOLER. So all in all about about £800. The difference is absolutely unreal! Would so recommend the upgrade...
Could you post up a sound clip / video of the custom exhaust please. Helps me with my research
:rofl:
Hi. Sorry for the late reply. Yes, I will get a clip to you when she is warm and ready! 👍
:driving:
cwunch
Post by cwunch » Mon Dec 13, 2021 8:21 pm
Dear all, greetings from Istanbul.
I have just bought a z4 20i, and get it remapped. On dyno, it was 158hp (? Probably because 95ron/91-92oct) and 275nm torque. All stock, stage1 tailormade map made it 260hp and 455nm torque (which is also zf8hp gear limit). Car become absolute fun, this is what it should have been in the first place.
Not pushing to the limits now, until I make a Liqui Moly engine flush + 5w40 synthech and ceratec.
One question; do u guys use drop in performance filters? Or go with the original paper ones?
Best regards
B21
Post by B21 » Mon Dec 13, 2021 8:54 pm
cwunch wrote: Mon Dec 13, 2021 8:21 pm Dear all, greetings from Istanbul.
Best regards
Congratulations….personally I would avoid using DCIs and /or gauze type filters..
The E89 airbox design is pretty good and using a quality filter , Mahle, FRAM etc and you won’t limit performance but get good protection..
If the car is over 25000 km fresh new plugs is a good idea too :thumbsup:
A very modified Atacama Yellow 35is :thumbsup:
cwunch
Post by cwunch » Mon Dec 13, 2021 10:18 pm
Thanks for the suggestions. It is 2014 model, with 80k km on it. Spark plugs and some gaskets have been changed. Car is fully serviced from authorised BMW dealer. I will try to keep OCI to 4-5k km/ 1 year.
I am also sure not to use any kind of open type filter for my setup. Even from the drop-in’s, I am looking for a dry one. Because back in the old days, I remember oiled filters were damaging air sensors… I will probably end up with a fine classic filter, which will be changed in oil intervals.
B21
Post by B21 » Mon Dec 13, 2021 10:25 pm
FWIW when I was dyno-ing mine it made 0.2 extra BHP with no air filter element in the air box..in 300bhp..
The BMW official maintenance program isn’t anything to write home about..oil n filter changes every 8km is prudent..
If it’s an auto a fluid n filter change would be good.. :driving:
Smartbear
Post by Smartbear » Tue Dec 14, 2021 2:18 am
This is the highest powered n20 I’ve ever seen verified on a dyno, it made this power using an n55 turbo & had forged internals. Eye watering :driving:
e85 3.0si sold
B21
Post by B21 » Tue Dec 14, 2021 11:06 am
Wow..glad I stopped when I did..that would have been nippy :driving: :driving: :driving: :driving:
sumotan
Post by sumotan » Wed Dec 15, 2021 1:00 pm
Best regards
Can ecu remap really produce 455nm of torque at the wheels ?????
cwunch
Post by cwunch » Mon Dec 20, 2021 9:28 am
260hp and 455nm torque is corrected engine data. (Whp seems 225hp) If you can make direct comparison, wtq can be about 390nm?
cwunch
Post by cwunch » Mon Dec 20, 2021 9:37 am
B21 wrote: Mon Dec 13, 2021 10:25 pm FWIW when I was dyno-ing mine it made 0.2 extra BHP with no air filter element in the air box..in 300bhp..
Redarding auto, I would like to share an important info. We have just serviced my brothers 420d, 2014 with 150.000km, at ZF original service center. We did not have any complaints, only a slight vibration from 3rd gear to 4th gear hard pull.
ZF technician was very happy that we have chosen to change the oil&filter. Because the used oil was very dark and water thickness. Which means it was not making its duty… If we had driven with the old oil, his guess was 20.000km max, until a complete transmission rebuild!!! (As you well know, BMW says it is life time, ZF says 100.000km)
B21
Post by B21 » Mon Dec 20, 2021 9:50 am
cwunch wrote: Mon Dec 20, 2021 9:37 am
QED :thumbsup:
SSF
Post by SSF » Thu Sep 15, 2022 7:53 am
Smartbear wrote: Tue Dec 14, 2021 2:18 amThis is the highest powered n20 I’ve ever seen verified on a dyno, it made this power using an n55 turbo & had forged internals. Eye watering :driving:
Isn't the gearbox rated to max 450 Nm of torque?
2016 E89 28i | Melbourne red | Kansas / Canberra beige
B21
Post by B21 » Thu Sep 15, 2022 8:40 am
SSF wrote: Thu Sep 15, 2022 7:53 am
The auto box is rated at 450nm but torque limiter s/w will back the DME to comply with those limits…suspect that car used a manual box..
