Electric Water Pump Failure - Poll
Has your electric water pump failed (N52 engines - facelift)?
Yes
34
27%
Not yet
91
73%
Total votes: 125
Smartbear
Post by Smartbear » Thu Mar 30, 2017 6:29 pm
DMC63 wrote: Thu Mar 30, 2017 6:06 pm
Smartbear wrote: Thu Mar 30, 2017 9:49 am
DMC63 wrote: Thu Mar 30, 2017 9:28 am
Now I feel left out, rejected, less than :( And slightly embarrassed :oops:
That would explain the rubber band thingy going round the end of it from the engine.
That's probably why it hadn't failed. It wasn't electric. Less to go wrong. Hehe.
That's probably why your car uses more fuel & produces less power, more parasitic drag on the engine :poke:
This thread is not going well, I feel even worse now :(
Cheer up, the suns out & you've got a convertible (with a working water pump) :P
e85 3.0si sold
DMC63
Post by DMC63 » Thu Mar 30, 2017 9:34 pm
Smartbear wrote: Thu Mar 30, 2017 6:29 pm
Thanks Rob, I feel much better now :D
BMW Z4 2003 2.5i and lots of bits and pieces - 2016 - 2020 Sold
Sinkrate
Post by Sinkrate » Thu Apr 27, 2017 10:12 am
Cost seems to vary massively for new water pump installs. Only called one Indy and was quoted £700. Anyone know the rough price to get one changed these days? Any recommendations Manchester / Liverpool area would be great. Thanks all.
Smartbear
Post by Smartbear » Thu Apr 27, 2017 10:20 am
Sinkrate wrote: Thu Apr 27, 2017 10:12 am Cost seems to vary massively for new water pump installs. Only called one Indy and was quoted £700. Anyone know the rough price to get one changed these days? Any recommendations Manchester / Liverpool area would be great. Thanks all.
Oem pump can be had for £240ish & it's an easy fit, an hours labour?
e85 3.0si sold
NickDE
Post by NickDE » Sun Apr 30, 2017 1:48 pm
Smartbear wrote: Thu Apr 27, 2017 10:20 am
I'm thinking of doing mine before it breaks. Which brand(s) are best, and where is the best place to buy ?
Darkness gone, go Darknes2, go Frozen, go Tronic
Sinkrate
Post by Sinkrate » Sun Apr 30, 2017 2:07 pm
I've got the pump down to £250 ish at https://www.gsfcarparts.com/ using the forum40 code.
Just need to find someone to fit it now and I'll buy it and get it sorted.
Online
Mr Tidy
Post by Mr Tidy » Sun Apr 30, 2017 10:47 pm
This thread is getting more positive - last time I posted the fail rate was 1 in 3, now it is more like 1 in 5! So not quite as big a problem as I first thought.
Mind you when mine did die there was no prior warning - everything worked fine until I stopped for fuel, then less than a mile from the garage it just went straight to the red on the temperature gauge and the warning light lit up.
I suppose the nature of how it fails is the aggravation factor - mechanical pumps whine, leak, etc. and give you signs they are failing whereas the electric ones just stop like you've turned them off with a switch. :x
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
bradz
Post by bradz » Mon May 01, 2017 9:19 pm
I Just purchased one from ebay for £221 Original PIERBURG pump.
Mine is showing no signs (My local indy said the fans staying on after the car has been shut off is an early sign)
I have been quoted £220 to fit it with a new thermostat and coolant.
I'm driving across Europe next month and its not really something I want to be worrying about as the car has just clicked 70k!
Z4M Coupe, E92 M3, E46 M3 Track car :driving:
GreyZed
Post by GreyZed » Sun May 21, 2017 10:38 am
bradz wrote: Mon May 01, 2017 9:19 pm I Just purchased one from ebay for £221 Original PIERBURG pump.
The Pierburg pump should be fine but make sure your Indy uses a genuine BMW stat as in dealer sourced and not an aftermarket 'oem quality' item. These are ECU mapped stats that have about 4 different modes they switch between depending on engine load/driving style etc. and the only one that will behave correctly is a dealer part.
3.0 auto, sterling grey, hardtop, prfessional nav, dsp, digital tv, bluetooth, cruise, xenons, mfsw, cupholders, auto lights, auto wipers, folding mirrors, memory seats, wind deflector, pdc, 108s, LED sides/fogs, stubby, intravee, need a quad exhaust!
grumps
Post by grumps » Sun May 21, 2017 10:54 am
Not yet, but still under 50k (just).
Start the day with a smile, get it over with.
Bog standard 2007 3.0si manual E86 in Montego blue with black leather, currently fitted with MV2s
85genius
Post by 85genius » Sun May 21, 2017 11:16 am
I got the pump for £210 off ebay (find the cheap seller on ebay UK then look through their German listings to save a tenner) then paid £90 to fit it and also repair one of my headlight washers. The mechanic told me he spent more time on the washer than the pump so I paid just under £250 all in to sort mine
Audi quattro driver :o
NOW SOLD - Ruby Black 3.0 SI Roadster :(
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
GreyZed
Post by GreyZed » Sun May 21, 2017 3:11 pm
85Genius...
A man in a dress destroyed your Silver Zed? :o
Jamesw
Post by Jamesw » Wed Feb 07, 2018 3:30 pm
Bought coupe at 60k, now on 91k and no issues yet. Not sure if done prior to my ownership. Good informative thread
Z4 Coupe, 58 plate, black, love it :driving:
Ducklakeview
Post by Ducklakeview » Wed Feb 07, 2018 5:29 pm
Jamesw wrote: Wed Feb 07, 2018 3:30 pmBought coupe at 60k, now on 91k and no issues yet. Not sure if done prior to my ownership. Good informative thread
As per thread, they do fail without warning. Some have been lucky and got to 100k, others have had them fail circa 60k. In the overall picture, £230-£250 for a pump isn't that bad, and about an hour to fit it. The thermostats are usually fine, normally cracking bodies is their problem.
Mike
keith777
Post by keith777 » Wed Feb 07, 2018 9:07 pm
Sinkrate wrote: Sun Apr 30, 2017 2:07 pm I've got the pump down to £250 ish at https://www.gsfcarparts.com/ using the forum40 code.
Try ducklakeview -a member on this site, located St. Helens I believe.
Cheers Keith.
