- philbo909
Fresh brembo pads and discs on the front, night and day difference, could stop a train!
- DSC_1172.JPG (88.69 KiB) Viewed 710 times
Sapphire black z4 coupe 135,000miles young
They would look better in my car
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Car back from powder coaters, Wheels looking better than new
- Mr Tidy
They look great "bowler".
The colour looks like a good match to your car and 107s are a lovely wheel!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- ben g
They look similar in colour to mine. Great choice.
Drove the car out the garage, washed and polished it, then put it back in the garage, trickle charger on cover on.
DaveZ4richardson
3.0i 2003 E85 auto cruise control, smart top module.
Fitted some x3 19s to my e46... It doesn't actually move now it's so low don't worry I'm raising it tomorrow
18 Z4s owned to date.
Current: 2.5i Titan silver
The leather of the steeringwheel was completely worn, so I had it replaced with nappa-leather, feels awesome:
Checked the roof drains. Driver side dry, passenger side had a puddle in there (roof motor is in the boot). Bottom drain clear, top drain the problem. Prod about with an old BBQ skewer cleared the problem, area now dry.
- Nanu
I find the main difference in the steering between sport and comfort is when on the motorway. Sport gives a lot more positive responseMarlon wrote: ↑Fri Jan 19, 2018 2:48 pmInteresting observations.Steve84N wrote: ↑Tue Jan 16, 2018 10:19 pmYou can change on the move.
When you hit Sport with the throttle depressed to any degree there is no immediate change. When you next lift off the throttle on reapplication it will have changed to give more throttle opening for less pedal travel.
When you turn Sport off with the throttle depressed it immediately goes back to normal which can easily be felt on the motorway as the car slows down slightly.
For ages I drove around in Sport everywhere except town where 1st gear is annoyingly jumpy. It is great for heel and toe. Then I started using normal again and found the steering better and even more involvement as more control over the throttle and more input required to get the same effect.
To be frank, electric throttle is a right royal pain in the arse on any car I can recall. I miss a good old cable as it did what you asked, nothing more and nothing less. None of this damped or oversprung response BS.
I drive around in Sport mode all the time - every journey is ignition on and button pressed. I prefer the lighter more responsive throttle response, however, I cant really notice any difference in the steering.
My understanding it that the steering feel is supposed to change in Sport mode - tighten up / heavier?
Leaving aside the throttle response, are you saying that you prefer the feel of the steering when not in Sport mode?
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Beatman
Relocated roof motor in to the boot, made a start on lolly pop bush replacement
My Car- 2004 3.0se sterling grey, mv3s , satnav, heated seats, ZHP.
New ones on Moz, prefer the standard blue. You still down under?
- Marlon
Based on Steve84N's experience I've been driving around this weekend not in sport mode and am quite enjoying itNanu wrote: ↑Sat Jan 20, 2018 8:52 pmI find the main difference in the steering between sport and comfort is when on the motorway. Sport gives a lot more positive responseMarlon wrote: ↑Fri Jan 19, 2018 2:48 pmInteresting observations.Steve84N wrote: ↑Tue Jan 16, 2018 10:19 pmYou can change on the move.
Gone: 3.0si 2008 E85
911 997 Carrera S
Got bored so thought I would look into why my rear drop door goes rat-ta -ta-tat when I open it. I think it the plastic bush moving out of it hole.
Now just glued bush in place
Waiting till Sunday and will test fit it and open it a few times to test for failure.
So removed it and taken door cover off to double checkNow just glued bush in place
Sterling Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Cruise and a nice warm garage. NOW GONE
Silver 3.0i Z4 NOW GONE
