enzed4
Post by enzed4 » Thu Oct 14, 2021 2:12 am
bazza190 wrote: Sat Oct 02, 2021 5:05 pm
bazza190 wrote: Sat Oct 02, 2021 3:15 pm New wheels day. Took a bit of a gamble on these. Ended up waiting 5 weeks and they turn up and it's tipping it down outside. :headbang:
Couldn't wait, curiosity got the better of me. They sent M14 bolts instead of M12. Just to top everything off so using old ones until new arrive. I'm quite happy with them :-D :-D
Don't know if anyone else has commented on these - but I think they look fantastic! Great choice :thumbsup:
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
Andres
Post by Andres » Thu Oct 14, 2021 6:08 pm
Like a brand new car now :driving:
Tango22
Post by Tango22 » Thu Oct 14, 2021 9:25 pm
Andres wrote: Thu Oct 14, 2021 6:08 pm Like a brand new car now :driving:
My new 70mm bonnet badge arrived today so planning on replacing mine at the weekend. Is it just a case of removing one of the kidney grilles, using a 10mm socket on the securing nuts then swapping the badges over? Ta.
Mr Tidy
Post by Mr Tidy » Thu Oct 14, 2021 9:49 pm
Yes that's how I did mine, but the nuts are a bit fiddly to get on as they cut a thread onto the plastic posts on the new badge.
Coupes because stunning!
Current - Silver Grey MC, Imola Red heated Nappa & carbon trim. Aeros, H & R Coil-overs, 224s, Strut brace, Nav, cup-holders, DSP Hi-Fi, pdc, cruise, MFSW, no CDV! E90 330i daily
Gone - Montego Blue
Gone - Ruby Black
Tango22
Post by Tango22 » Thu Oct 14, 2021 9:51 pm
Mr Tidy wrote: Thu Oct 14, 2021 9:49 pm Yes that's how I did mine, but the nuts are a bit fiddly to get on as they cut a thread onto the plastic posts on the new badge.
Cheers!!! Will get it done at the weekend.
Andres
Post by Andres » Fri Oct 15, 2021 6:54 am
Tango22 wrote: Thu Oct 14, 2021 9:51 pm
I've put a tiniest bit of silicone under the new badge, probably not necessary, but it would hurt to loose such an expensive piece of plastic :D
Tango22
Post by Tango22 » Fri Oct 15, 2021 1:14 pm
Didn't have any silicone to hand so used a couple of small strips of thin 3M trim tape underneath the badge. The old nuts were tricky to remove but got them off eventually. Chuffed with the results, new badge and old badge below:-
Dark Diggler
Post by Dark Diggler » Fri Oct 15, 2021 5:55 pm
Changed the belt, tensioner pulley and alternator clutch pulley, fairly easy once I’d worked out the right tools for the job, the parts were cheap from Autodoc and the tools I bought didn’t break the bank. Give or take it cost the same as an hours labour at an Indy and it took less than an hour to do with no drama :)
Online
DMike
Post by DMike » Sun Oct 17, 2021 7:52 pm
Sorn and oil service today. I have most maintenance tasks printed as PDFs from TIS but keep returning to these easy instructions viewtopic.php?t=16657 when changing the oils.
True-Blue
Post by True-Blue » Sun Oct 17, 2021 8:52 pm
EDIT - Just wanted to point out that if you’re going to try this you need to make sure the sponge material is properly wet and don’t apply very much pressure at all. This stuff is abrasive and can ruin leather if you’re not very careful. :!:
I’ve had a PM asking about it, so thought it was worth clarifying :thumbsup:
Started to clean it, 45 mins with a magic sponge, some water and a Microfibre…
From this…
To this…
Not perfect, but it’s a start :)
E85 3.0 Si MSport in Sapphire Black, with red leather, Piano Black trim, BC coilovers and a Scorpion Cat back 8)
Previous Z4’s : E89 20i in VO, E85 3.0Si Silver sold at 29.5k miles, E85 Silver 3.0Si se, E85 3.0i, E86 3.0 Si, E85 2.5si
jock156
Post by jock156 » Sun Oct 17, 2021 9:16 pm
Gave it a clean 🧽
Wwesty
Post by Wwesty » Sun Oct 17, 2021 9:57 pm
Gave it the first proper clean since we bought it and happy to say no hidden surprises! :thumbsup: :thumbsup:
2004 Black Sapphire 3.0L SE.
blunderthumbs
Post by blunderthumbs » Sun Oct 17, 2021 10:01 pm
Wwesty wrote: Sun Oct 17, 2021 9:57 pm Gave it the first proper clean since we bought it and happy to say no hidden surprises! :thumbsup: :thumbsup:
Stop it you're killing me. Really regret letting her go :telloff: :headbang: :cry:
2004 Black Sapphire 3.0L SE. Red leather. Back box delete. Clutch valve delete. Roof motor relocated. 18" M star spoke style 193. Machine Monkey exhaust tips. Gap Tec. ZHP Gear knob. Clear side repeaters. Zun Sport lower grille.
Wwesty
Post by Wwesty » Mon Oct 18, 2021 9:13 am
blunderthumbs wrote: Sun Oct 17, 2021 10:01 pm
:( Sorry!
Barty
Post by Barty » Mon Oct 18, 2021 10:00 am
Took delivery of these items…
Both to be fitted early November when we’ll be working on the car anyway 8)
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrün Metallic E86 3.0Si / Insta @bartsbimmer
