Hard to see because if the spoke design but this is what it looked like on my roadster. However I’ve since pulled them off as I’m getting ready to swap over to my coupe.
- Dubbedown
Follow latest mods on Imolarot_S54 M Coupe OEM+
De badged the wings and gave it a polish
- 9963D1A2-E707-471F-8F6F-D365D367F30D.jpeg (236.06 KiB) Viewed 692 times
- A3A30E5F-5DBF-4447-A030-9835E99DC8FF.jpeg (244.97 KiB) Viewed 692 times
2009 09 Carbon Black Cinnamon E86
- chanlon1
You wouldn’t be up for selling one of your badges? I’m missing one….
E86 Z4 Coupe 2006 Silver
Sorry mate. Came off in bits so only fit for the bin
- chanlon1
No worries. Off to AliExpress then for a fake!
- 3gGT01
Dubbedown,
Whoa, that hardtop fits really nicely! Looks good with your yellow caliper color combo!
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
- 3gGT01
Dubbedown,
Just curious, do your front tires ever rub the fender interliners on your vert? It looks great lowered though!
- Dubbedown
lol yes in that picture it did, but that was literally the day I threw on the calipers so I didn’t know what to expect. Doesn’t help that style 32 are very sunken in, offering no spoke clearance whatsoever so I had to slap on a giant 20mm spacer. But once I got home, I raised the fronts slightly, removed spacers and switched over to my square set of 224s (18x9 et30), which are what I used at Watkins.
For my coupe I have no doubt they will fit as I’m running staggered 19s off the F80 M which have rather low offsets. Without spacers they already sit flush, and the calipers should fill out the wheels nicely. FWIW I plan to keep the factory suspension and ride height on this car.
Red and yellow… going for the McDonalds theme lmao.
Got around to doing a job that always bugs me on Z4s - the dreaded front brace. As always the bolts were bitches and stripped the heads!! Off with bumper, bolts drilled out, brace and bonnet catch resprayed and 6mm allen head bolts fitted. A few other bits cleaned, sprayed and tarted up
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- Dubbedown
What exactly was wrong with the brace? This is first time I heard that it needed to be replacedSimon 3.2M wrote: ↑Sat May 20, 2023 4:24 pm Got around to doing a job that always bugs me on Z4s - the dreaded front brace. As always the bolts were bitches and stripped the heads!! Off with bumper, bolts drilled out, brace and bonnet catch resprayed and 6mm allen head bolts fitted. A few other bits cleaned, sprayed and tarted up
Hello mate, didn’t mean to worry you. It was done purely for cosmetic reasons. They lose their paint and corrode eventually as they are aluminium - structurally they are fine, the just look a bit scabby that’s all.Dubbedown wrote: ↑Sat May 20, 2023 5:38 pmWhat exactly was wrong with the brace? This is first time I heard that it needed to be replacedSimon 3.2M wrote: ↑Sat May 20, 2023 4:24 pm Got around to doing a job that always bugs me on Z4s - the dreaded front brace. As always the bolts were bitches and stripped the heads!! Off with bumper, bolts drilled out, brace and bonnet catch resprayed and 6mm allen head bolts fitted. A few other bits cleaned, sprayed and tarted up
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- inkey$
Today I sent one of my children to sleep with the sweet sweet sound of a naturally aspirated straight six.
Previously: Z3R 2.8 • E46 330i • Z4R 3.0 • Z4///MC • E90 335i • Z4///MR • Z3///MC 'Breadvan' • Z3R 2.8 • E30 325i R • Z4C • Z4R 3.0
- Dubbedown
Buffed the headlight lenses do take full advantage of recent projector upgrade. Had to do 2 passes but very happy with final outcome.
First pass with 800 grit Final result
- 3gGT01
Dubbedown,
What was the projector upgrade you did? Lense turned out very good.
- Dubbedown
Thanks man! Afterwards I noticed one or two spots that could use extra compound so I’ll finish the rest later in week. Goal is to get it crystal clear before I apply PPF to the front end in a few weeks.
Few weeks back I swapped out the tired OEM Hella xenon projectors with a set of aftermarket ones but it’s 99.9% PnP and requires no cutting/baking of the housings. Projectors can be pulled directly out from the back much like a bulb swap but with few extra steps. But the difference is clarity and output are quite significant.
viewtopic.php?p=2004063&sid=6b03da2d785 ... f#p2004063
Backroads never looked so clear
- IMG_6271.jpeg (36.64 KiB) Viewed 374 times
