Great work, can you post some photos of your ride height, please? Keen to see how the car looks!W63 wrote: ↑Mon Aug 22, 2022 6:05 pm It took me about 6 hours with a jack and axle stands on the driveway. The solinoid replacement was the most frustrating due to very little access between the outer and inner wing. The Shocks and Springs were relatively straight forward. no special tools required.
- Griffo46
2007 3.0si Roadster Stratus Grey/ Red Leather
2016 520d F10 M Sport Space Grey
- Vornwend
MOT - passed but advised to renew rear tyres soon. Was hoping to get more than 9,000 miles from them (Michelin Piot Sports) but maybe the NC500 had something to do with that
Now: 2004 Z4 3.0i - Merlot Red
Before: VW Corrado VR6 Storm - Classic Green
Torquay.
Now - G31 520d
Now Gone - E86 Carbon Black 30Si Sport.
Gone - E39 2.5i sport
Gone - F20 1 series
Gone - E39 3.0d se
Now - G31 520d
Gone - F20 1 series
Gone - E39 3.0d se
Torquay.
Now - G31 520d
Gone - F20 1 series
Gone - E39 3.0d se
Now - G31 520d
Gone - F20 1 series
Gone - E39 3.0d se
- Argyll Andy
Maybe
Congrats on the pass
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
Torquay.
Now - G31 520d
Gone - F20 1 series
Gone - E39 3.0d se
Now - G31 520d
Gone - F20 1 series
Gone - E39 3.0d se
- Griffo46
Torquay.
Now - G31 520d
Gone - F20 1 series
Gone - E39 3.0d se
Now - G31 520d
Gone - F20 1 series
Gone - E39 3.0d se
- MikeyH
Work beginning to get to me, so went out for a nice evening drive. Lovely
- Barty
Had the aircon regassed and checked. Lost 145 grams over the last 2 years, so bang on 10% per year which is about the norm. Refilled and ready for the Croatian roadtrip in two weeks
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- colb
Got around to fitting some Led bulbs to the Z4, been meaning to brigten up the sidelights as the standard 501 bulbs look rather yellow.
Some faffing around getting at them through the access panels in the wheel arches. Plugged the new Leds in and tested them before installing them back into the headlight shell. Nice white colour produced, a great improvement over the old standard bulbs. The Leds were advertised as being canbus error free but I did get a failed bulb light on the dash. Fitted further Leds to the side repeaters, number plate lamps and boot interior light. Then plugged the car into the laptop and coded the bulb check out using BMW Scanner 1.4. Dash warning light no more.
Led bulbs off ebay, UK supplier https://www.ebay.co.uk/itm/203293895706 ... name=11050
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
Just getting round to refurbishing the vanos unit on my Z4MR that I bought last week, defo needed to be done as there were flat spots on acceleration. Couple of hours in and had to take a break as my back started playing up... Going to be a long night
- IMG_20220825_180903.jpg (178.22 KiB) Viewed 419 times
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
- Barty
Finally got round to giving the Zed a proper wash. Ready for an alignment session tomorrow
- Barty
Upper NS ball joint was worn. New item in and then a full alignment. Blend of M3 CSL and original Z4 configuration, with the rear camber getting a particularly good looking at, since this was fairly aggressive in its setup. Back to -2.05 (was at -3.40) both sides, with a 0.08 toe in. Front toe close to zero and camber at -1.20.
Result: a car that’s more stable at speed (toe-in was out between sides), a rear end that comes round a bit more eagerly under power, and an improved turn in. Zed feels a lot more planted and less prone to tramlining and following input from poor surfaces. Happy days
- Mr Tidy
Fitted the bonnet bump stops I bought from a forum member - cheers Wassup.
Just hope I've put them on the right way round!
There's still a bit of movement at the front edge on the passenger side though, so it looks like time for some more research.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
