- jock156
- TOMGREEN413
Great job Sir..........hope your backs not to painful after a 30 hour detailing stint!!!
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
- Barty
Slightly, but that’s part of the job. Thankfully the studio has a lift so we can work at a slightly more convenient heightTOMGREEN413 wrote: ↑Mon Jan 23, 2023 10:19 pm Great job Sir..........hope your backs not to painful after a 30 hour detailing stint!!!
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- TOMGREEN413
What lighting system are you using, it looks epic
- Barty
Thanks! It’s a great mix of looks and utility
We combine hex-lights -used for texture checks (orange peel) and sanding- with localised spots -used for clarity and checking deep cuts- to get the best possible view of the paint. The hex lights we imported from China (rather than going through a local reseller) and the spots are also used to light up large warehouses. We use two to spot the flat surfaces, and two mobile ones for the sides.
- TOMGREEN413
I need to find something similar as my strip light are pants
Built its new front struts up, with all new parts. Spring plates etc. are not very expensive from Cotswold BMW. Shocks and Eibach’s from AutoDoc
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
- MikeyH
Very nice
I want to go out to the garage and get on with it, but it’s cold
Started hunting down the cause for lean codes
- IMG_20230125_112452_edit_32017256062301.jpg (164.94 KiB) Viewed 625 times
2005 e85 z4, 2.5
- fedbeast
Todays upgrades will be a resonator delete for those pops and gurgles by supersprint, third brake light white edition from ecs tuning, and a full interior led lightening replacement.
Total upgrades $630.55
- 31FED965-18D8-4A6B-862C-103225003FE9.jpeg (54.94 KiB) Viewed 534 times
- 94667603-ACB5-4689-B73E-1784D9F991EB.jpeg (87.03 KiB) Viewed 534 times
- fedbeast
True-Blue wrote: ↑Wed Jan 25, 2023 7:03 pm Built its new front struts up, with all new parts. Spring plates etc. are not very expensive from Cotswold BMW. Shocks and Eibach’s from AutoDoc
What was the price for these from Cotswold bmw? Cheapest ive found for front and rear full set was $998
Hi, it was only the spring plates, rubber spring seats/mounts, washers and nuts that I bought directly from BMW, not the shocks and Springs, they came from AutoDoc.fedbeast wrote: ↑Thu Jan 26, 2023 9:24 pmTrue-Blue wrote: ↑Wed Jan 25, 2023 7:03 pm Built its new front struts up, with all new parts. Spring plates etc. are not very expensive from Cotswold BMW. Shocks and Eibach’s from AutoDoc
I don’t think the pricing will help you much as I’m not sure AutoDoc will ship to the USA? They’re based in Germany, but have registered offices in the UK so we don’t pay import taxes.
- Barty
Dropped off the Zandvoort-bumper for repairs. The fit of the replacement bumper isn’t up to par, and this saves me the trouble of measuring and cutting the rear bumper once the new diffuser arrives, which should be around next weekend
Front adaptive shocks and wiring carefully removed and replaced with the Bilstein B8 front shocks, Eibach springs and all new spring plates, rubbers and washers. Rear next, but probably not this weekend as have other plans… I’ll start in the evenings next week.
