dropped the car off to get 224's put on the car with new tyres and hunter alignment.
even though the tyres fit (asked on here before hand) the garage says because they aren't the recommended size they might take extra time to put on therefore extra money. they only put the ones designed for the alloy on the rims apparently and this isn't the "right" size. so shall see what they say. they also said folk on forums talk a power of shite. so there you go. will see how long it takes them to do the job.
probably won't use this garage ever again. they did have 4 bentleys sitting waiting to get work done and a classic car about 50 years old. so it's a well renowned place that deals with upmarket cars.
- MikeyH
Typical, any excuse to charge more money for basically the same job. Surely they are taking the pi$$.SonnyA85 wrote: ↑Tue Aug 02, 2022 10:37 am dropped the car off to get 224's put on the car with new tyres and hunter alignment.
Onlinepatriot66
What size tyres are you having fitted then ?SonnyA85 wrote: ↑Tue Aug 02, 2022 10:37 am dropped the car off to get 224's put on the car with new tyres and hunter alignment.
I have 215/45 R18 (fronts) and 245 40 R18 (rears)patriot66 wrote: ↑Tue Aug 02, 2022 11:08 amWhat size tyres are you having fitted then ?SonnyA85 wrote: ↑Tue Aug 02, 2022 10:37 am dropped the car off to get 224's put on the car with new tyres and hunter alignment.
the exact same setup as mr wilks
Onlinepatriot66
So the same profiles as ///M and only 10mm narrower front and rear. Wouldn't have thought that would cause much of a problem in fitting ?SonnyA85 wrote: ↑Tue Aug 02, 2022 11:44 amI have 215/45 R18 (fronts) and 245 40 R18 (rears)patriot66 wrote: ↑Tue Aug 02, 2022 11:08 amWhat size tyres are you having fitted then ?SonnyA85 wrote: ↑Tue Aug 02, 2022 10:37 am dropped the car off to get 224's put on the car with new tyres and hunter alignment.
yeah 10mm narrower to hopefully prevent them from rubbing but up a profile size from what i have on my 108's currently to hopefully help ride comfort
- MikeyH
I have 224s on my 2.2 e85 and they are front 225/40 and rear 245/40 Avons with Bilstein b4s and I have no rubbing but it looks like standard height ride. But the back wheels do stick out a little more than I like.SonnyA85 wrote: ↑Tue Aug 02, 2022 1:09 pmyeah 10mm narrower to hopefully prevent them from rubbing but up a profile size from what i have on my 108's currently to hopefully help ride comfort
- enuff_zed
Well you've certainly taken that on board.
- Scubaregs
Whole new level........
- Argyll Andy
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
Onlineronk
Had the run down from ijmuiden to Montabaur . Top down all the way and air con blasting full tilt in the 35° temperature.
It was a good clear run at a good pace - The car feels very planted at speed.
I didn’t go daft, just the odd run up to 120 but mostly 90 ish!
Fuel consumption suffered of course but I did.t buy for economy
- bigwinn
Changed the oil filter housing gasket
140k and 19 years hadn’t been kind!
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Onlinepatriot66
A grotty mess and that gasket looks flat as a pancake Was it hard and brittle Stu ?
- bigwinn
I was surprised how it didn't break up like the valve cover gaskets do but it was flat out like a badger on a bypass Si
EWS Delete PM me
EWS Delete PM me
Just finished giving mine a good wash. Used a pressure washer attached to a hosepipe, then rinsed it down after the wash again with a hosepipe and even rinsed the drive down afterwards using the hosepipe on full blast.
Living up North has it’s advantages
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
