PAC_Z4_F31_110Puma
Post by PAC_Z4_F31_110Puma » Tue Dec 06, 2022 6:39 pm
Engine rebuild process now in the final and slowest stages consisting of multiple trips to BMW parts to get alu bolts, finding everything and getting it back in, good excuse over Christmas to slink off to the garage.
2006 E85 3.0Si - Restoring a previously unloved gem. Addressing all common faults one at a time..
F31 - rapidly approaching 200k miles & Defender 110. Glutton for mechanical punishment.
Regret the username... Peter
grannyknot
Post by grannyknot » Tue Dec 06, 2022 11:09 pm
PAC_Z4_F31_110Puma wrote: Tue Dec 06, 2022 6:39 pm Engine rebuild process now in the final and slowest stages consisting of multiple trips to BMW parts to get alu bolts, finding everything and getting it back in, good excuse over Christmas to slink off to the garage. IMG_7085.JPEG
Beautiful! That silver will certainly let you see any oil leaks, nice work.
2008 E86 M coupe
Toronto, Ontario
MikeyH
Post by MikeyH » Wed Dec 07, 2022 12:28 am
Always impressed by someone that can do a job like that. :thumbsup:
Barty
Post by Barty » Wed Dec 07, 2022 8:06 am
Wow, great job! :thumbsup:
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
T_J_G
Post by T_J_G » Wed Dec 07, 2022 4:31 pm
Refitted fixed GM5 unit, and everything now works as it should. :driving:
E85 2003 Z4 3.0i
BumpyZ4
Post by BumpyZ4 » Wed Dec 07, 2022 9:48 pm
T_J_G wrote: Wed Dec 07, 2022 4:31 pm Refitted fixed GM5 unit, and everything now works as it should. :driving:
:thumbsup:
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
Redmex
Post by Redmex » Thu Dec 08, 2022 6:05 pm
After getting quotes of between £200/£300 to supply and fit an offside front brake caliper and we will probably want to put new discs and pads this was quick fit, other local garages too busy and need the car dropped off for all day.
I bought a caliper for £48, brake fluid for £3.50 and maybe an hour and a half to change it myself, I bought a brake bleeder that connects to an inflated tyre but never used it as I had a tube from my old Gaggia coffee machine lying beside a jam jar and let gravity do its thing for 1/2 hr as the reservoir is right above the caliper. The caliper was unfit due to burst seal as I had checked the bolts and greased them with a wee bit silicon grease and didn't work
I will buy new discs and pads maybe 2 calipers from auto doc soon and refresh the front brakes
Drunkpanda42
Post by Drunkpanda42 » Sat Dec 10, 2022 12:51 pm
Left it alone - far too cold!
Scubaregs
Post by Scubaregs » Sat Dec 10, 2022 4:32 pm
First "wash" in weeks. Rinse car, snow foam and leave for 5 minutes, rinse again and dry off. The benefit of ceramic coating.
Image Image
Drunkpanda42
Post by Drunkpanda42 » Sat Dec 10, 2022 5:38 pm
Scubaregs wrote: Sat Dec 10, 2022 4:32 pm First "wash" in weeks. Rinse car, snow foam and leave for 5 minutes, rinse again and dry off. The benefit of ceramic coating.
You missed a bit - on the bottom of the door sill - half baked job
Scubaregs
Post by Scubaregs » Sat Dec 10, 2022 5:42 pm
Drunkpanda42 wrote: Sat Dec 10, 2022 5:38 pm
That was left for contrast. :rofl:
Image Image
Barty
Post by Barty » Sat Dec 10, 2022 5:59 pm
Crashed it. Coming out of turn 12 at Zandvoort I started to accelerate out of the corner, lining up for an overtake when I went onto the wet. The moment that happened, the back snapped out and I slid onto the wet grass, at which point you’re a passenger. In the last moment on the tarmac I managed to slightly adjust my angle, preventing me from sliding into the metal barriers, instead ending up backwards square into the tyre barrier. The right corner just “kissed” the metal barrier, showing what damage I would have had on the entire right flank had I not corrected in that final moment.
Ultimately it’s just plastic and carbon, and nobody got hurt other than my ego :? New bumper arranged on the way home, diffuser is cracked and torn, scratches on the hatch and rear quarter panel, but nothing that won’t sand out.
Now where’s that 18-year old Macallen… :headbang:
N4LLY
Post by N4LLY » Sat Dec 10, 2022 6:10 pm
Barty wrote: Sat Dec 10, 2022 5:59 pm 163581C3-290D-43E2-A755-9CD37493DE38.jpeg
Crashed it.
Oh crap, so sorry for you :(
2014 20 M sport Valencia Orange
MikeyH
Post by MikeyH » Sat Dec 10, 2022 6:37 pm
Oh no, I feel your pain :headbang: :cry:
MKZ4000
Post by MKZ4000 » Sat Dec 10, 2022 7:25 pm
That will buff out
BMW E85 Z4M
BMW E85 Z4 2.5
Gone Z4 E85 3.0
