Managed to get the Z4MC laser aligned using Hunter tech. Front o/s toe was off by a couple of minutes only but somewhat noticeable. Now it drives so much better and feels more planted
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
- DMike
Oil service with new filters, DISA inspection and goodnight until spring.
2005 Z4 3.0i Sterling grey
- ronk
I sorned my car on the 31st October and the Dvla cheque arrived 4th November- today I attached the battery maintenance charger - and I suspect just in time as it showed 11.8 v at the start of the process.
- Barty
Impromptu cars&coffee this morning with 4 other coupes
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
Wrapped the gear shift cover.
- Screenshot_20221108-132427_Gallery.jpg (107.38 KiB) Viewed 747 times
- Dark Diggler
- Barty
Oh they are hilariously huge; 20 inch, don’t even want to know the width but those tyres are stretched more than Mrs. Incredible on a bungeejump
- Griffo46
Gave the car a good clean, took it around the block to drain the water and left it in the sun to dry. Parked it up and put the new half cover on too, pleased with it.
- 2874BC69-7CD5-4C62-904D-2CC29698BDA9.jpeg (207.14 KiB) Viewed 608 times
2007 3.0si Roadster Stratus Grey/ Red Leather
2016 520d F10 M Sport Space Grey
The fresh paint on my E89 has had long enough to ‘Gas Out’ and cure now, so I’ve ordered another CarPro CQUK 3.0 kit to ceramic coat it over the weekend.
I’ll be doing a gentle polish with a very soft jeweling pad to remove any paint shop buffer trails, there aren’t many at all but might as well make it perfect. Followed by a wipe down with IPA, before applying the ceramic coating.
It’ll then stay snuggled up in the dry until next weekend for full curing
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
- New front wish bones
- New Goodyear F1 A. 6 fronts
New wish bone bushes
New track rod assemblies
New drop links
Painted new door handle trims
Wheel alignment
New zed for me, this time a phoenix yellow Si
Standard procedure of coilovers new wheels and new lollipops first off
- 20221111_183014.jpg (192.68 KiB) Viewed 430 times
18 Z4s owned to date.
Current: 2.5i Titan silver
- N4LLY
Jeeshh jamie_z4,
Is that number 16
Is that number 16
- smorris_12
I've just changed the brake fluid on mine. Must reset the thingummy too.
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
Scott
