Thanks bud. Your project is on another level. Amazing how quickly you have turned the car around since the little incident.
- SGRG
Current:
Z4MC 2007
Porsche Cayenne 2019 (Black / Bordeaux Red two-tone leather interior)
Previous:
X5 40D 2011
E92 M3 manual 2011
Z4 3.0 2003
Honda Prelude 2.2 1997
Honda Civic Coupe 1995
Z4MC 2007
Previous:
X5 40D 2011
E92 M3 manual 2011
Z4 3.0 2003
That interior looks perfect for that car.
MOT and oil change. Both went splendidly. Not one advisory.
- TOMGREEN413
Lovely wheel n car combo
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
- PaulN
I’m interested in the spray for a discoloured leather steering wheel… not Z4 though, can these be bought in a rattle can and other colour options?
Everything Happens for a Reason!
14 TT Black Edition
07 Z4 2.0 SE Jet Black
06 Freelander Sport Java Black
14 TT Black Edition
Thanks Tomgreen413 & Mre75_bim.
Was thinking of changing the 108’s at some point to CSL reps.
- TOMGREEN413
my Coupe is on the 108s and after much consideration my mind has moved away from Rep CSL alloys and l think I'm going to go for something like the 5 spoke blades or similar..........those CSL wheels do look great BUT.....EVERYONE seems to stick them on.so I think I'll be a little different
TOMGREEN413 wrote: ↑Sat Feb 04, 2023 12:25 ammy Coupe is on the 108s and after much consideration my mind has moved away from Rep CSL alloys and l think I'm going to go for something like the 5 spoke blades or similar..........those CSL wheels do look great BUT.....EVERYONE seems to stick them on.so I think I'll be a little different
- TOMGREEN413
/attachment]
Once these are done, suspension, brakes, engine / cooling refresh next.
After around 2 weeks of pain correction/ detailing she's done. (Well almost, just a couple of tiny marks I need to revisit) I'm not sure how many hours of work but believe me , this was a serious challenge but I'm over the moon with the results, just goes to show that so long as you've got a good clear coat to work with anything is possible. I've still got the engine bay,, interior, wheels and inside the wheel Wells to do , plus a new set of front fogs to install. Once these are done, suspension, brakes, engine / cooling refresh next.
- 20230204_161630.jpg (229.45 KiB) Viewed 547 times
Fitted new control arms today. Saved by the old whitworth spanner from those bloody 21mm nuts. At least the new ones are 19 and 22mm. I went with Delphi in the end and they are superb quality.
- IMG_20230204_162357.jpg (129.2 KiB) Viewed 527 times
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
Couple of hours in the garage this afternoon, completed the front B12 install… we’ll just double checked all the torque settings really and popped the wheels back on.
Then, onto the rears. Rear drivers side was dead easy, little bit of a faff with the E89 boot trim, but not to bad.
Rear passenger side seems a bit of a PITA; gaining sufficient movement on the relevant trim pieces to access the top of the strut is really bloody annoying. Feel I must be missing a clip somewhere, I’ll have another look in the morning
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
B12 installation all complete.
The rear boot trim is a bit of a faff, but fresh eyes this morning spotted a couple of extra ‘push-clips’ (not sure what the correct terminology is for these) which, once removed, made moving the trim much easier.
Was going to take the car for a quick blast to test it out, but apparently we have other plans
Managed to retrieve the roof motor after 2 hours of cursing and jumping in an out of the boot. Turns out, it was a classic case of a flooded motor.
Next steps are to remove the motor and clean it up. The bolts are fully siezed so had to park it for now as the Alan key from some IKEA furniture I'm using isn't cutting it even with copious WD40!
- IMG_20230205_145530.jpg (269.48 KiB) Viewed 403 times
- Barty
Replaced the failed washer fluid pump and replaced the filter while I was at it; at about 50p it was an expense I could just about justify
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
