Special order through Venoxy https://venoxy.com/ . Let them know what you want and they will get back to you with a mock up . Once you are happy with what you see it takes about 2 weeks from the time you place the order . I first saw them on this post here https://www.zpost.com/forums/showthread.php?t=1730660 which is worth a read before fitting them and there is a you tube video by E91 Kiter https://www.youtube.com/watch?v=lbj2tSZvzI0&t=752s.
- 1536Z4
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
Cheers mate that’s great1536Z4 wrote: ↑Mon May 29, 2023 8:48 amSpecial order through Venoxy https://venoxy.com/ . Let them know what you want and they will get back to you with a mock up . Once you are happy with what you see it takes about 2 weeks from the time you place the order . I first saw them on this post here https://www.zpost.com/forums/showthread.php?t=1730660 which is worth a read before fitting them and there is a you tube video by E91 Kiter https://www.youtube.com/watch?v=lbj2tSZvzI0&t=752s.
2009 09 Carbon Black Cinnamon E86
Well, after giving 19 years service my original expansion tank developed a hairline crack that opened up when hot which led to this :
I shouldn't have needed to remove the fan/shroud assembly but I couldn't get the tank free from the plastic housing it sits on.
A quick run out and all seems well.
All back together now with a new Meyle tank, cap and a Febi level sensor.I shouldn't have needed to remove the fan/shroud assembly but I couldn't get the tank free from the plastic housing it sits on.
2004 Sterling Grey E85 2.5l
Had lovely day out in it with the Mrs, before giving it a little bath before bed…
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
- Barty
Triple threat at Zandvoort yesterday. Ceremonially gave the barriers at turn 12 a wave as I headed back to the main straight for a straight-six blast, grinning ear to ear
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
Past it's MOT with zero advisories at 111k! A few more bits to sort and then it's time for some summer fun!
Just checked all the lights are okay ready for tomorrow's M.O.T
- patriot66
Looking good Dan No advisories makes an MOT pass all the sweeter
- TOMGREEN413
Well done Sir !
MOT today as well and again, no advisories at 103k .....Happy about that
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
M.O.T passed but with an advisory for "Suspension arm ball joint has slight play Nearside Front Lower" guess that it will eventually need this https://www.autodoc.co.uk/febi-bilstein/1877552
That’s it. I’d do the pair thoughbunk58 wrote: ↑Wed May 31, 2023 12:58 pm M.O.T passed but with an advisory for "Suspension arm ball joint has slight play Nearside Front Lower" guess that it will eventually need this https://www.autodoc.co.uk/febi-bilstein/1877552
Passed M.O.T. with advisory's anti roll bar rubbers and steering inner and outer joints so had them done and re do the four wheel alinement all done and set to go yippee
- darich
In the past couple of days:
Fixed faulty/temperamental 12v socket
Changed grilles for black ones
Replaced screenwash reservoir grommet but still got a small leak
- R6M20885DRP.jpg (214.98 KiB) Viewed 327 times
Previously 2004 Sterling Grey E85 3.0SE
Currently 2007 Silver Grey E86 M Sport
Instagram - Zed4Coupe
- darich
Can't take any credit for that...it was an owner before me.
