Looking great
- Argyll Andy
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
Fitted genuine E46 19” M3 wheels Just need some spacers for the front now
- 56216839-5593-4D1D-BDC3-95426AD47A43.jpeg (271.69 KiB) Viewed 647 times
- 9C1E913D-32F5-4739-B15B-B324F521B305.jpeg (210.91 KiB) Viewed 657 times
- DCFBD335-B2BA-44F6-AF34-001AAECADFE1.jpeg (167.23 KiB) Viewed 657 times
Late registered 09 E85 M Performance Si Sport with a mod or ten…
- Argyll Andy
They look good but those rear rims look very vulnerable/exposed, or is it just the picture? what width is the wheel/tyre?
- Alpina 98
The rear tyres look too narrow. Any slight kerbing will end in tears.Argyll Andy wrote: ↑Sat Nov 21, 2020 9:36 pmThey look good but those rear rims look very vulnerable/exposed, or is it just the picture? what width is the wheel/tyre?
I'm going to bed early on New Years Eve
Not wishing to toast the New Tier in.
Sometimes you have to compromise to do something different - it would have been easy to throw on some 19” ET35’s but was never going to be easy with an ET27 rear when lowered on H&R
I had a 4 vert with 20’s dropped on its ass and didn’t kerb it in 3 years - to be fair, if you kerb your alloys you’ve got to ask yourself whether you should even be driving...
- 8560FC7A-45A3-4996-AD2E-770438FE1305.jpeg (321.16 KiB) Viewed 629 times
- Argyll Andy
I’m all for something differentZ4_ATB wrote: ↑Sat Nov 21, 2020 10:28 pm Sometimes you have to compromise to do something different - it would have been easy to throw on some 19” ET35’s but was never going to be easy with an ET27 rear when lowered on H&R
I wasn’t thinking about kerbing, on the roads up here I’d be worried about potholes or stones etc on the road, the rim just looks so close to the tarmac with what looks like little or no protection from the picture. I was wondering more if a wider tyre would protect the rim better
- Alpina 98
I'm not brave enough to tell my wife she should not be driving
Exactly - it’s only when I saw so many posts about how these would only fit a Z4M unless loads of work required on an E85/E86 that I wanted the challenge
They came with 255/35 fitted but under compression they touched the arch lip - so a smaller/better angled sidewall would be required unless rolling the arches, so I went for the most dramatic tyre side first to confirm they can be used (225/35 on a 9.5 rim) and will move up to a 235>245 maybe even 255/30 each change depending on rubbing
- Big Andra
I do like the look of those wheels on the e85 as I once thought about getting a set myself, but, after all the faffing about I had getting style 32's to fit, i just couldn't be bothered with the hassle again. Sensible wheels from now on for me
2009 E89 2.5 Alpine white.
Finally fitted the powerflex lollypop bushes.
Turn-in feels much better (even though I have my squishy winter tyres on) and the tram-lining has reduced.
Just need to do the front ARB bushes now. They are very oval shaped! Big ol' gap at one side of the ARB. Not sure if I should go poly or rubber for those.
2006 Z4 2.0i Ruby Black
- bigwinn
Cleaned
Gave it a blast to blow the cobwebs away
Hopefully fixed the leak in the boot by finding the near side lamp full of water- re sealed and re seated
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- DSGRNMCM
So tried to get my car on my mates lift, to do the Gearbox oil. Had to use wood to lift the car high enough to get the lift pads clearance under the jacking points.
But
The lift has adjustable arms, long at rear and short at the front. But I could not get the arms to fit my jacking point pattern, both driving in and reversing in. Bugger. So I will try it on my drive.
Did get a quick snap of our cars together!
But
E86 Z4m Coupe - Titan Silver, Stubby, Sun protection, Eibach springs, LED interior lights, CDV delete, Badge delete, Pipercross, Exhaust bypass
F11 520d, E46 328i, E91 320d, F21 120d, E46 318ti
Mk VI GTD DSG (Daily Hack)
- TheDan
Assembled some new front shocks with springs, all new bits! Will be fitting them tomorrow along with new lower control arms, track rod arms and drop links.
Quick question for you lot who have got the front reinforcement plates... What do you do about this screw/stud that is circled in the photo? Just unscrew it and leave it out?
I would drill a hole in the plate My top mounts don’t have the locating screw.
Bagged E85 Z4 3.0i
E90 330d
E90 330d
