A very good use of time and it`s free
- 1536Z4
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- 1536Z4
Two things today.
Had the underside of my 05 treated by rust busters who provide a rust prevention treatment. Seemed like a good idea. Time will tell.
Secondly, for what feels like a milestone, I finally got the dreaded transport mode deleted. Two cables down and no luck with INPA I rashly took a risky purchase off a Chinese obd scanner site. To my amazement a Foxwell 530 actually arrived. Still convinced it would be a knock off the fact it registered was equally good news. Good to go with the BMW addon I plugged and found the delete transport mode option. Finally I can turn the blower up and down and demist the rear.
- jock156
- sw4nny
Left it at the side of the road,after getting stuck in the snow this morning on the way home from work
Online
Put it all back together underneath following the clutch, flywheel and associated parts.
The only thing I am not happy with is I can not find an O2 post cat sensor anywhere, I replace one in the summer and have now replace the front 2 and wanted to replace the 4th one a post cat O2 sensor Bosch appear to have stopped making or supplying them other makes are not the right length cable and today I found that the plugs are different, I was aware that there is a short and long one but the plugs are different as well.
Main dealers are a large increase in price for the same thing but may end up there
In live data the voltage seams to drop out then return so it is not in the best condition and this brings on a warning light.
OnlineVijay
Gave her a good wash and filled the tank up...
How much is Shell now..!
- IMG_3832.jpg (36.36 KiB) Viewed 657 times
2007 Z4 3.0Si Coupe, Carbon Black, 53K on clock & counting...
Mineral White M240i
Mineral White M240i
- BumpyZ4
Changed the Oil Filter Housing gasket, Intake rubber boot, fuel injector o-rings, refreshed the CCV system and cooling system sans the radiator. Picture is of some of the pieces parts.
- Pieces parts.jpg (180.5 KiB) Viewed 626 times
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
despite the bad weather over the weekend we still made it to Donnington and showed people what the Z4 could do (whilst being careful due to weather conditions).
https://youtu.be/6jkC7EcJwjw
- Barty
New calliper fitted, fresh MOT with compliments from the mechanic on how well it looked despite being an 06 car. Well- apart from the disgustingly dusty front right… that’s been remedied now
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- Mau
Also needed a new one recently (also for a coupe living in the Netherlands ), albeit it my left rear caliper being somewhat stuck. Luckily not in relation to an MOT.
My first idea being the same as yours; no biggie after almost 14 years / 195.000 kilometres.
Did you just fit one new caliper? I as advised to replace both calipers on the same axis simultaneously (both by the AA and my fully Z3/Z4 oriented indy), which advice I took.
More on the '03 roadster and '08 coupe:click me.
- Barty
Sound advice, and reached the same conclusion. Difference is, I'll replace the left-side myself. Saves me about 100 euro's over my local having to do it for me. So new calliper on orderMau wrote: ↑Mon Nov 29, 2021 1:43 pmAlso needed a new one recently (also for a coupe living in the Netherlands ), albeit it my left rear caliper being somewhat stuck. Luckily not in relation to an MOT.
- Tango22
Went out for a 'play' in the snow. Haven't owned a RWD car for over 20 years (last one was a Vauxhall Carlton GSi 3000) so it was 'interesting' driving in the white stuff
2006 LCI E85 Z4 Roadster 2.5i M-Sport | Montego Blue
2021 BMW M340i Touring G21 | Dravit Grey
2010 BMW K1300S | Lava Orange
2000 Aprilia RSV Mille | Hot Red
- Barty
Really like that pic, particularly where you can see the internal reinforcements under the bonnet where the heat from the engine hasn’t worked quite as far through the panel yet. Must have been good fun
