- Tango22
Cheers, is that the 'weighted' type I take it?
2006 LCI E85 Z4 Roadster 2.5i M-Sport | Montego Blue
2021 BMW M340i Touring G21 | Dravit Grey
2010 BMW K1300S | Lava Orange
2000 Aprilia RSV Mille | Hot Red
- Mr Tidy
Yes, that's the heavier ZHP one. Had one on my previous Coupe and it really is much better than the OE fitment.
If you do buy one just make sure it is the genuine BMW one with that part number.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Tango22
Perfect, I will pick one up from that seller then. Thanks.
I have just fitted new rear lower coilspring rubbers and fitted upper ones from a 3 series e46 to increase the ride height by 8mm on back ... has stopped the bottom dragging on my drive hump ... no difference in handling that I can detect, maybe slightly less jarring on bumps due to slightly thicker rubber on top mount
2004 z4 3.0i Sterling silver
x5 40d m sport black sapphire metallic
Transit custom
Transit custom
- ronk
Just had an email from the broker:-
Further to our conversation in connection with the above policy and sorning the vehicle over the winter months. Your insurer Highway have come back advising, they normally don’t cover SORN or laid up vehicles. One of the reasons is they are giving comprehensive cover when this is not needed. Cover should be downgraded to something like accidental damage + fire and theft , fire and theft cover only or a laid up policy, unfortunately they don’t have these cover types available.
They have agreed to continue cover up until your renewal date on the 10/03/2021 at that point the policy will expire. We will at that point need to look for a new provider for you.
Perhaps they would rather I didn’t reduce the risk over the winter months - especially so as I wasn’t asking for any cost reduction!
- Scubaregs
ronk, yep, totally weird and I don't understand it. Worth knowing however as we all know insurers will wriggle out of sa claim if they can.
- ronk
I can’t understand it
If I’d been asking for cash back I could have understood their reluctance. I bet there are more claims in the dark days of winter!
- DMike
Brake fluid flushed today. Service interval indicator seems to messed up
2005 Z4 3.0i Sterling grey
Torqued the engine to gear box bolts up re fitted the starter motor.
- Tango22
Ordered a ZHP gearknob from the seller ocsltd linked to earlier. Looking forward to getting it fitted and trying it out.
Those who have swapped over gearknobs, whats involved in removing the old one and fitting the new one? Does the old one just pull off or is it held on with a small grub screw for example? Ta.
- Barty
Pull firmly and choose: face or balls. You’ll end up hitting either depending on that very decision.Tango22 wrote: ↑Sun Oct 31, 2021 6:48 pm Ordered a ZHP gearknob from the seller ocsltd linked to earlier. Looking forward to getting it fitted and trying it out.
The original is held on with no external factors such as grubs or the like. Simply pull up to remove.
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- ronk
Best to open the roof . Stand the seats and pull up firmly - as others have advised, try and avoid damage to the family jewels.
Anticipate the trajectory if you can.
- Tango22
Noted!!! Thanks.
So fitting the new one should be just a case of pushing it on?
Wet sanded and polished a repair I had to do on a wheel arch where I caught a sticking out screw on my workshop door frame. How I hadn't noticed the screw before I'll never know
Glad you got one, you’ll love it! My old one slid off surprisingly easy and didn’t hit myself!! Yeah the new one just pushes on, you just need to give it a bit of a thud at the end so it ‘seats’ properly. I just used the palm of my hand and gave it a whack, job done.
