- axelleveau
Did have a talk with a front caliper starting to stick (pushed piston back and forth a few times to free and lube the seal). I will have to do a proper overall of the front brakes but I need the car right now so hope this will do the trick for a little while
On that note, what would people recommend? New calipers or rebuild? I am on the fence as even if I get new ones I'll have to paint them anyway and still have to source new hoses alongside...
Gone - Ford Ka MK2 Petrol - Black
Will hang around to carry materials/people and in emergency - Ford Fiesta MK7 1.0 Ecoboost - Black, white rally rims, white decals, remapped
Now - Z4 Coupe - Montego Blue: Here
OnlineMikeyH
I thought about it a long time and although it seems easy to do the rebuild myself, I in the end opted for just changing for Pagid refurb ones as this was easier and quicker. I did the R/H front first as it was jammed, cost me £67.00 from Euro Car Parts. Now at Halfords only £31 something. Bought one for the L/H front and will do at my leisure.axelleveau wrote: ↑Sun Mar 05, 2023 5:15 pm Did have a talk with a front caliper starting to stick (pushed piston back and forth a few times to free and lube the seal). I will have to do a proper overall of the front brakes but I need the car right now so hope this will do the trick for a little while
- axelleveau
Oh I will check ECP but looks like a pair of new Ridex is sub £100 from Autodoc as well (not sure if yours fit 325mm discs?), guess I better paint over a fresh caliper after a light sanding than fight crusty old ones with a wire wheel...MikeyH wrote: ↑Sun Mar 05, 2023 5:56 pm I thought about it a long time and although it seems easy to do the rebuild myself, I in the end opted for just changing for Pagid refurb ones as this was easier and quicker. I did the R/H front first as it was jammed, cost me £67.00 from Euro Car Parts. Now at Halfords only £31 something. Bought one for the L/H front and will do at my leisure.
Edit: Checked and ECP remanufactured Pagid are twice the price of Ridex from Autodoc. Halfords does not have any option. Bigger brakes, bigger money
OnlineMikeyH
I've just checked for a 3.0 coupe and my wife's Ford Focus, I see what you mean. 2.2s are still £31.56 for the fronts. How odd! At those higher prices I might have given it a go at doing it myself.
Odd. If I put my old coupe reg into Halfords it comes up with Pagid fronts for £51.36 and Pagid rears for £35.04. I think I’d prefer Pagid to Ridex, but only because Ridex always seems to be cheapest option for everything on AUTODOC and generally you get what you pay for.
If you want stick with OEM, you will need ATEs which will cost you rather more.
Refurb is another option, but before you do anything else pull out and clean the slider pins just to make sure it is actually the piston that is sticking,
2003 Maldives Blue 3.0i auto
Popped into Cotswold Cheltenham to look at the classics and pickup a new OEM gear knob. Came home to find the genuine 3.0i kidneys I bought of FB marketplace (for just £10!) had arrived. Fitted those and gave the car a wash! Cleaned the standard 2.5i grills and applied trim dressing.
2003 E85 Z4 2.5i SE Roadster Titan Silver Manual
- 1536Z4
Looking good . Need to see them on a car
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- axelleveau
Well, I realised I was dumb and was only looking at the cost for Left+Right as a set. Autodoc has each side individually for £31.5 including the 39% off today so I bite the bullet and ordered each side as well as a set of F+R Wezmoto stainless lines from Ebay (that was planned anyway for both safety and aesthetic and I'm afraid the lines are rusted in the caliper). If in a rush I will fit one caliper as is and do the painting later or if time allows I will hold on and paint from newZedebee wrote: ↑Sun Mar 05, 2023 7:16 pm Odd. If I put my old coupe reg into Halfords it comes up with Pagid fronts for £51.36 and Pagid rears for £35.04. I think I’d prefer Pagid to Ridex, but only because Ridex always seems to be cheapest option for everything on AUTODOC and generally you get what you pay for.
- 1536Z4
Replaced whole accellerator pedal and brake pedal rubber .
- 20230219_105715 (1280x960).jpg (128.56 KiB) Viewed 564 times
- 20230217_115840.jpg (183.13 KiB) Viewed 564 times
Managed to score a cheap hardtop in the neighbourhood. I couldn't resist.
- O7A63ws.jpg (335.06 KiB) Viewed 502 times
Fitted some nice freshly refurbrd wheels
- 20230307_175528.jpg (151.65 KiB) Viewed 498 times
18 Z4s owned to date.
Current: 2.5i Titan silver
Onlinejock156
Both of the above looking sharp!
- paddy wright
Changed my coolant sensor- easy job and a how to video to follow.
- SqerrNipz
Fought my way 60 miles through the sleet and snow, to RBM. Car having X8R vanos kit, service, coolant flush, brake fluid changed, cracked spring and various little leaks sorted.
Can’t wait to get it back!
Proud owner of ‘Xavier’ - Maldive blue, 2004 3.0 auto. Heated/electric msports, style 107’s, gravity performance exhaust, E46 330i brakes, custom heated steering wheel, custom carbon intake, lots of other tweaks!
- SqerrNipz
Picked my car up from RBM today. Full X8R vanos refresh, X8R DISA kit, new rear springs and RTAB, few little leaks sorted, new thermostat and engine, coolant, brake service.
£1500 but what a drive back home! Honestly feels like a completely different car. I knew my vanos probably needed some love after nearly 100k, but it’s absolutely transformed it. Throttle response feels so much better and pulls all the way through. Sport mode is almost scary now!
Given her a whole new lease of life and I feel much more confident driving, knowing all the little niggles have been sorted
