Post
by tomoz4white » Tue Jan 24, 2017 2:43 pm
Okay Dokey!,
Just picked up the Zed and the garage has now done the following:-
1) Fitted the Resistors to make the "horizontal top strip completely redundant (and bulbs removed)", this has cancelled out the dash warning light coming on and the side indicators are no longer lighting up (hooray!).
2) The Drl ECU function was activated but the halo's do not light up as Drl's
3) The Halo's are therefore only functional via the side light switch (the "manufactured intention" but they light up without the horizontal strip working as I wanted).
4) H7 Osram Nightbreakers Unlimited have been fitted and the headlight level slightly raised (I will find out later when night falls and see if there is any improvement).
I guess the question is....am I frustrated that the Halo's are not set up for DRL Function? Well, not really. On the way back home from the garage, I asked the Mrs to drive in front of me and observe the halo's as I switched them on and off via sidelight switch. She commented that they are not "DRL Bright" and in the winter sunshine, she had to look a second time to see if they were on. Someone else did say that they are not super bright (bulb changes not an option) so it's not a real biggy. I am quite happy to switch the sidelights on for the "halo look" - and it's not a deal breaker that my back lights are on at the same time - who cares!
Summary - "whether the halo lights are on or completely switched off" the Sonar's still make the car look so much better (in my opinion) and I am de-gingered at the same time. My ultimate goal was to:-
1) Enhance the car's appearance = Achieved
2) Cancel out the Side Light horizontal strip = Achieved
3) Increase dipped headlight performance = Probably not Achieved (tonight's test pending!),
As in 3), I am not exactly confident that the dipped headlights this evening will WOW me in the pitch darkness, but that's not a biggy either as the OEM's were also shocking as we know. The car is rarely used during darkness but I will certainly report back later for everyone's information.
P.S - with regards to condensation, this seems to have calmed and there has been no "misty misty" for the last 4 days or so.
So there you have it - am I pleased?. I think that's a Yes!
Tomo
Only UK OEM White Manual
E85 3.0i SE Still Rolling!
Mileage 36,000 Miles
4 x White 3.0i OEM UK E85's Made...
= 2 UK Pre-Facelift / 2 UK Facelift
