Just fitted the Storm Motorwerks V2. Quality piece of engineering, very weighty and it does smooth out the notchiness of the gear change. It's a little shorter than the original and after a little experimentation I secured it a little higher on the shaft which means the throw is original (and a little longer) but shift is even easier. I suspect most would prefer a shorter shift.
Original is 85g
ZHP is 174g
Storm Motorwerks V2 is 452g
Anyway, in short it's a recommendation from me.
Knob Comparison
Knob Comparison
- 20161210_144334_001.jpg (48.15 KiB) Viewed 1120 times
- 20161208_212318.jpg (58.41 KiB) Viewed 1120 times
- 20161126_102617.jpg (49.7 KiB) Viewed 1120 times
- 20161210_155422.jpg (78.95 KiB) Viewed 1120 times
2004 3.0i, manual, toledo blue
- Ewazix
Knob Comparison
Comparing and weighing your knob, higher on the shaft etc. You knew exactly what you were doing
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- Marlon
Knob Comparison
^^ this
its too easy
. . . refraining from the double entendres if I can, its interesting to see just how much heavier the stormwerks V2 is
its too easy
Gone: 3.0si 2008 E85
911 997 Carrera S
