Transmission fluid change
spearman
Re: Transmission fluid change
Post by spearman » Fri Feb 17, 2012 4:41 pm
Just wanted to give my feedback on the transmission fluid change...
I read this forum as I had a clunky 1st-2nd gear change. decided to change the gearbox oil despite it being lifetime fluid.
I ordered the MTF-LT-2 fluid from the local dealer. £105!! ouch! only comes in 5litres. The gearbox uses 1.2l so i've got 3.8l if anyone wanted to buy it (im based in southend, essex).
Paid a local independent £30 to change it over for me.
It's def made a difference to the gear change. Maybe a 20% improvement.
Sometimes 1st doesn't want to slip in, and have to put it back neutral, lift the clutch, and then try again. normally goes in ok after that.
This doesn't happen often though. maybe 1 in 25 attempts.
2nd gear always clunks in. No problem at speed though, flies through smoothly.
I guess the gearbox/clutch is designed to be driven hard.
anyway, hope this helps.
I've got 2004 3.0i
2008 ///M Roadster
ChawenHalo
Post by ChawenHalo » Sun Jul 29, 2012 10:22 pm
Sorry also digging up an old post. the guys who look after my car told me also that it was a lifetime oil. there is a magnet part inside the gearbox to catch metal particle that float about.
Is it actually worth doing or is it asking for throuble. The M used a ZF box I think.
Z4MC. ACS CF diffuser silencers side skits. Pagid RS29 & Goodridge. Gruppe M Bilstein B16PSS10 H&R ARBS. Delage Sport chassis. MPS2. Audi A8 4.2TDI 2008 runabout.
sam1832
Post by sam1832 » Sun Jul 29, 2012 10:59 pm
ChawenHalo wrote:Sorry also digging up an old post. the guys who look after my car told me also that it was a lifetime oil. there is a magnet part inside the gearbox to catch metal particle that float about.
I done mine a few weeks back
The gear changes are a lot less notchy now
So I would say defiantly worth it
Sent from my GT-I9300 using Tapatalk 2
Gone - '03 3.0i Z4 Roadster Sterling Grey -
Z4 Project Thread
Now got E64 '57 650i - My 650i
tomotomotomo
Post by tomotomotomo » Tue Nov 06, 2012 1:00 pm
Do the transmission and differential plugs have a washer? If so, are they re-usable or would they be replaced when the fluid is changed?
2003 E85 3.0i Roadster, sterling grey, premium audio, 107s w/ Kumho KU39, heated black leather
sam1832
Post by sam1832 » Tue Nov 06, 2012 1:40 pm
tomotomotomo wrote:Do the transmission and differential plugs have a washer? If so, are they re-usable or would they be replaced when the fluid is changed?
They have a seal in the plug
I replaced the whole plug as it was a couple of quid at bmw
Z4 Project Thread
mr wilks
Post by mr wilks » Tue Nov 06, 2012 5:38 pm
Adam D wrote:Looking forward to getting mine changed tomorrow albeit for the BMW MT-2 fluid, fingers crossed it smooths out the notchyness a little. :thumbsup:
90k on my auto & smooth as you like . in fact way better than DSG gearbox on mrs w's golf
have you tried "resetting" the gearbox ?
http://www.bimmerfest.com/forums/showth ... p?t=411543
Z4s , i've had a few :oops:
Si Sport E86 Ti silver - syrah trim - quad conversion
Adam D
Post by Adam D » Wed Nov 07, 2012 8:14 am
My 3.0 had a manual gearbox, the later spec oil/new oil did help the shifting though.
Silver Grey 2007 Z4MR which needs to be driven more :evil: :P :cool: :D :thumbsup:
Jdaviac18
Post by Jdaviac18 » Tue Oct 15, 2013 3:59 am
I just put in 70w80 MTL G-4 into the z less that 1000 miles ago. I see everyone is recommending D4 ATF is the 70w80 ok or should i change it to the D4 as soon as possible?
