Another thread on this forum got me thinking about this so I thought I would ask the general forum. My interest in ride height is because I've heard a variety of numbers for the difference between the standard and sport (M) suspension on our non M cars. I've been told everything from 0.5 to 1.5 inches with 0.5-0.75 being the most common. I'm not aware of a spring brand which differentiates the amount of drop between standard and sport suspension oem ride height, if it makes a difference. (The sport/non sport springs could have the same height to maintain the same amount of travel while the spring supports are lower on the sport then the non-sport cars.) Since the question seems to come up on a regular basis, now might be a good time to find out.
To eliminate any differences in height for the various front bumpers, a good standard to use would be:
Option 1: The distance from the top of the fender wheel arch to the ground.
Option 2: Measure the distance from the center of the wheel (center cap) to the top of the fender wheel arch.
Measure both fronts in case there is a side to side difference. Using the fronts also helps to minimize differences in gas tank fill. If you have non stock size tires or springs please identify. For those using English measurement, please round to nearest 1/8 inch.
For those of you who wish to measure both methods and all four corners please do so and post. I can always create another listing with the additional info.
Thanks, I'll try to add to this as people contribute. If there is enough response, I will format into a easy to read/compare list and post.
2007 3.0Si Coupe - Sport suspension Stock tire size. Option 1
driver side = 26 inch passenger side = 26 1/4 inch Avg = 26 1/8 inch
Option 1 Avg Hgt
26 1/8 inch - 07 Si Coupe sport suspension, stock tire size
Option 2 Avg hgt
14 1/8 inch - 03 non sport
13 3/4 inch - 03 as above with Dinan package
14 inch - 07 Si Coupe sport suspension
Option 3 Avg hgt. ("attach measure to rim flange at bottom middle and measure to lower edge of wheel arch.")
601 - 04 SE sport suspension
587 - as above with Eibach Pro Springs (Drop = 14mm = .55inch)
Option 1 Avg Hgt
Option 2 Avg hgt
