Heavy / Sticky steering
spic
Post by spic » Sun May 15, 2016 12:00 am
Have a look at the pics a little way down, (if they haven't already been linked in) I did originally drill where recommend but it felt like I had hit the main colomn bar but not made an opening into the cylinder so I then basically drilled the sides No 8 in the steering column diagram, I then used a long straw for spraying the lubricant making sure to try and get it in all directions inside the cylinder while wring the steering wheel from lock to lock, then plugged the holes with very short self tappers and a small bit if sealant, it's a easy enough job just be carefully not to go crazy with the drill, the metal is really soft and if you go steady you can feel it about to go through.then that's it :thumbsup:
spic
Post by spic » Sun May 15, 2016 12:07 am
viewtopic.php?t=50994&start=90
The pics are in this link but I see it's been posted a while back
RayM
Post by RayM » Mon May 16, 2016 7:28 am
spic wrote:viewtopic.php?t=50994&start=90
Cheers Buddy :thumbsup:
Porsche 997 Gen 2 Cab - awesome
Melbourne Red 35iS (Gone to a new Home)
3.0 SE E85 Maldives blue (Now gone but not forgotten)
Previous toys:- 2.0 Litre Westy, 993 C4
z4all
Post by z4all » Mon May 16, 2016 4:51 pm
this looks seriously complicated. is there anyone around the Watford/Harrow area that does this job?
touring_style
Post by touring_style » Mon May 16, 2016 7:57 pm
z4all wrote:this looks seriously complicated. is there anyone around the Watford/Harrow area that does this job?
It isn't complicated really - it seems like an extreme and daunting prospect, but ultimately all you're doing is drilling a hole and spraying in a lubricant.
It looks complicated because of all the photos and detailed descriptions people have uploaded but once you've figured out where to drill and the hole is made the rest is simple - you'd be crazy to pay a garage to do such a straight forward job that can be done with basic tools.
2004 2.2i SE
z4all
Post by z4all » Mon May 16, 2016 8:57 pm
I really don't trust myself lol. Hopefully there is a member nearby that can help. Don't mind paying!
RayM
Post by RayM » Fri May 27, 2016 12:00 pm
Finally got around to doing this today as I was waiting for the lubricant to arrive.
Took off the panel and low and behold there's a hold already been drilled by a previous owner so in the lube went.
Should the effects be instant or does it take a few miles to take effect as there seems little difference?
touring_style
Post by touring_style » Fri May 27, 2016 12:20 pm
In my case the effect was instant - which make sense because the lubricant should have reached the area it needs to straight away.
Did you definitely put enough in?
2004 2.2i SE
RayM
Post by RayM » Fri May 27, 2016 7:03 pm
Yeah I think so. The hole was 5-6mm round so I could put the nozzle tube extender thing right in in and put loads in until it was running out over my hands and soaking the dust sheet I had put down.
It looks like however did it before used some type of grease as there was signs of it on the outside of the hole. It might take a little while for the lube to work its was around or through this gunk. I've been out in it again since the last post and considering the temperature here today and the mileage I've done its not too bad at all.
gov
Post by gov » Fri May 27, 2016 7:52 pm
What exactly are the symptoms you are experiencing Ray - I'm now getting paranoid - even comparing the power steering on my DD to the zed . I have RFT's which doesn't help with the feel on the road - my steering is never notchy and you can turn the wheel while driving just using your little finger and it rights itself when you've turned the wheel but now I'm convincing myself it does feel slightly heavier when hot :roll:
RayM
Post by RayM » Sat May 28, 2016 8:49 am
gov wrote:What exactly are the symptoms you are experiencing Ray - I'm now getting paranoid - even comparing the power steering on my DD to the zed . I have RFT's which doesn't help with the feel on the road - my steering is never notchy and you can turn the wheel while driving just using your little finger and it rights itself when you've turned the wheel but now I'm convincing myself it does feel slightly heavier when hot :roll:
Gov, I thought I was getting a bit paranoid too. I've only noticed this heaviness/stickiness in the last month or two when the ambient temperature has risen. A better description is notchey rather than heavy. Sometimes it seems tricky to make minor adjustments on straight roads. My Indy tried it and just thought the steering was a bit heavy but not much else.
Mine is nothing like as bad has some have described on here though, and I might just be being hyper critical as this car is 13 years old and my daily driver 6 months old. Tech moves on.
Certainly does not effect my driving pleasure too much :)
gov
Post by gov » Sat May 28, 2016 9:31 am
Know where you're coming from Ray - at the end of the day the early cars are getting a bit long in the tooth and perhaps we are getting paranoid - have to remind ourselves it's not like a new or nearly new car worth silly money !
Tony
z4all
Post by z4all » Sat May 28, 2016 9:20 pm
Can anyone in the Watford area help me with this?
BlueBoy
Post by BlueBoy » Thu Nov 17, 2022 4:45 pm
RayM wrote: Sat May 07, 2016 10:11 pm
touring_style wrote:Here are some links to forum pages that I gleaned information from;
http://www.bimmerforums.com/forum/showt ... ering-Fix/
http://www.z4-forum.com/forum/viewtopic ... 4&start=90
http://www.pistonheads.com/gassing/topi ... 411724&i=0
I was quite thorough reading up on it to find out which lubricant would be best for the job.
In the end I went for the Wurth HHS 2000. It was only £10.00 of eBay for a decent sized can.
http://www.ebay.co.uk/itm/252042958515
TBH I can't remember the reason that product was my final choice (I made a short list of 5 or 6) but at the time I thought it was the best overall option. :?
Ultimately there's a large plastic cog and worm wheel that you need to get lubricant to. When they get warm they expand and cause the notchy feeling through the steering wheel. The lubricant relieves this.
The casing that holds the large cog is soft metal and easy to drill into to enable a lubricant to be inserted and drench the cog - thus eliminating the friction with the worm wheel.
Some guys mounted a threaded grease nipple onto the steering column to pump in grease, but I opted to do what others had done and drill a hole (which is just left open) and spray a decent amount of lubricant in. The hole sits above when the lubricating oil drips down to so nothing leaks out of the hole.
I did cut the plastic pipe that the lubricant exits the can from at 45 degrees at the end that buts up against the hole you've drilled to enable the lubricant to be fired into the hole a bit better - it was a bit messy spraying the stuff into the casing with drips going everywhere so cover your floor mat!
The photos in those threads will give you a better idea of where to drill than I can explain here.
Spend an hour or so reading up on it and looking under your dash and it'll soon become clear - I'm a bit fik and I managed it! :P
With a sharp drill bit its a straight forward job. The issue went away for me immediately so I can only assume it was successful and I've had no issues at all as a result of using the Wurth product.
Sorry the above is all a bit long winded! :roll:
Good luck.
Thanks very much for that great write up. I will have a good read through as you have suggested and give it a go.
Thanks again :)
So I tried to drill to the shaft. Using a 1/8" drill bit, I easily made it to a 5/8" depth but with just a visual inspection it appeared that the bit was not all the way through the housing. Tried again, with less pressure but could feel that the bit was not penetrating any further and was hitting a solid surface. I then looked with a scope to see if there could be a gap between the housing and the shaft to indicate that I may need to drill deeper. Did not notice a gap. Question....are the tolerances between the housing and the shaft in close tolerance so I would not see a gap? And is the 5/8" a max depth? How do you know when you penetrated the housing? Maybe I should follow up with a larger bit so I could see down the hole a bit easier?
Thanks!
M@_
Post by M@_ » Sun Nov 20, 2022 4:45 pm
Adjusting the ring is a BMW approved method to correct sticky steering and it’s easier to do with no risk of damaging the column.
I hope you’ve tried this already. I’ve not you should consider the correct fix.
I feel like this info needs to be posted in all the drilled column threads.
2003 z4 3.0i MT 3.07 ratio
2003 3.0i
