How to remove kidney grills?
- nb67
I have a new bonnet badge to attach but I need access to it's underneath so that I can fix the securing tabs to it.
How do I get access to do this. It looks like if I removed a kidney grill then I could get my hand in to do the job but I can't see how to remove the kidney grills.
Any ideas peeps?
Any ideas peeps?
GONE - 3.0i SE. Sterling Grey. 2005.
Gaptech RCH+, ZHP, Stubby. CDV Delete.
Re: How to remove kidney grills?
Lift them up and pull them tomards you
My cars: http://WWW.GARAGET.ORG/PHILLY
- nb67
I did try that but they didn't 'pop' out straight away so thought they may have clips that needed some help.Philly_Sweden wrote:Lift them up and pull them tomards you
Thx buddy, I'll try with a bit more force tomorrow.
Yep they just pull out. I did this last week. Just give it a bit more elbow
- nb67
Does it matter which way you pull them? e:g best to pull from the top or from the bottom?Serpentine722 wrote:Yep they just pull out. I did this last week. Just give it a bit more elbow
- srhutch
- Moderator
From the bottom.
- mr wilks
I remove them by gently pulling down whilst sliding a butter knife along the top edge until you feel the clip then gently lever with a cloth between knife & paintwork . They should pop out a treat
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- nb67
Cracking advice as usual.
I have trim removal tools so will try with the thinnest one along the top edge while pulling the grill out.
- Confused®
- patriot66
No tools required. With two hands get hold of the bottom of the slats and firmly push upwards whilst pulling the lower edge outwards and the grille will come out easily.
- Marlon
This is useful advice for fitting the Ram air scoops many of us are about to receive
Gone: 3.0si 2008 E85
911 997 Carrera S
- mr wilks
The grills as far as i know have the same clip fitments on top & bottom
if OEM fit they can be difficult to lever out the first time ,if rep grills or been out previously they do come out easier i found
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Beetlegav
Push straight up using the slats with slight inward force and then pull the bottom out
2second job
2second job
- nb67
Superb advice lads, thank you.
Popped out easily with a bit more effort and front badge fitted so easily afterwards.
Online
Thanks for the advice, replacing mine soon!
Z4 now sold
Current - M235i
Current - M235i
